Hi All
I recently picked up a CS rev counter (with the slightly higher rev limit) in pretty good condition, but there are water mark stains on the inside of the glass.
Is there a way of opening the housing to be able to clean the glass?
Anil
Hi All
Anil
You have to get a screwdriver (or similar) and carefully pry up the swaged side of the bezel. When you are done, carefully bend it back. Not too difficult as the metal is quite soft. I did this when i replaced a resistor in mine.
Good luck. :)
