Hi All
I am in the process of backing my 911 SC which now has the 964 look and I'm taking it back to a 3.0 RS ish look. The rear lights including the reflector with the reversing lights that are currently fitted are 964 I think can anyone tell me the differences between the two and to get the correct look do I need to change them all and if so has anyone got any they may sell.
Also I've seen where you can replace the reflector with a panel has anyone done this and how does that affect the reversing lights.
Thank you
911 reversing lights are in the light units, not the centre reflector.
Hi
Are you sure about that I am out of the country at the moment so I can't check but I'm sure when I removed the reflector in the past the reversing lights were attached to it. Hope you are right as it will make things a lot easier for me.
Is it me but I think the op thinks he has 964 light units and the 964 panel which does have reverse lights built in ala mick Dundee and wants to know difference between 964 and earlier types which is the answer given ... earlier cars have the reverse lights in the corner units not the reflector .
Hi All
Thanks for the info, so I take it if I fit new SC lights I would be able to do away with the rear reflector, that's all I needed to know.
Cheers for that
