Fitting wheel spacers to an SSE?
The standard wheel set upon the SSE just looks a tad to inboard for me, especially the fronts. For those of you who have this months Total911 have a look at the Targa article on page 37 to see a rear view of my car.
I think they could take at least 15mm on the front and about 10mm on the rear.
Does the SSE already have spacers fitted?
Can you get a shim in a 10mm thickness?
How exactly are adaptors fitted? Do you have to change the existing studs?
Richard
Im not sure if all but some SSE's had 28mm slide on spacer on the rear with a 930 part number. I have a set in the garage.
If your studs are long enough you can fit these types of spacers and I did to my SSE.
You can buy them on ebay new or used.
You could just bolt a 40mm ish adaptor to the rear if you remove the 28mm shim
Fronts would need longer studs and a shim but I would be careful on the front as you may mess up the steering with anything too big, 7mm can be used with standard studs and nuts.
