apesman
1974 911 Restoration
Hi all, Well I thought it was time to show the progress on my restoration 911.
A bit of back ground info... I've owned in the past a 1966 912 and a 89 3.2 Targa, both great cars but used very little so I thought I would buy a project :doh2:
Just to warn anyone thinking of restoring a Porsche make sure you have large pockets!!!
Anyway, this is the first time I saw it, the engine and box had been removed (but still came with the car) and a lot of parts had been "borrowed" from it.
What made me want to restore this car?
Well in my opinion I think its a rare narrow bodied 74 911, the original colour is Sahara Beige RHD with matching engine and box, a sunroof and running on cookie cutters, built in 1973 and as I found out later running a lot of the parts from the pre-impact model.
After I removed every part left on the car
I decided to have it striped by Envrio-strip...that`s when the nightmare started.
This is how it came back
erm bit of work me thinks.
Ouch!
Really pleased to see a restoration thread though! Keep it coming.
All achievable though. Buy yourself a Mig welder and get stuck in - your pockets won't need to be as deep then. Look forward to more updates...
FF
After assessing the body work I made a list of new parts needed,
o/s front inner wing,
n/s front inner wing,
a complete new roof with sunroof, (the existing sunroof hand been covered over and chopped around),
o/s and n/s narrow body rear wings,
Complete new floor,
Inner and outer sills,
Tank support,
Battery support,
Front cross panel,
Longitude/wheel housing repair sections.
They were the main parts but other bits along the build were needed.
All parts that were available from Porsche I ordered at my local dealer, the other parts I sourced from various places like Roger Bray, Rose Passion and the like.
It had a become a major build now beyond my scope so I sent the whole lot away to leave that bit to the experts.
Now the body was away it was time to work my magic on the parts that were left.
I started with the rear axle trailing arms, this is how they came off..
I have a sand blaster at work and also brought a plating kit, what was salvageable I reused if not good enough I replaced.
The worst part of this refurb was replacing the bearings by heating up the arm and freezing the bearings, here is the finished product.
Trailing arms done.
Edited by apesman
The inner wings are a nice price aren't they...?!
Hi Simon, I think the inner wings came in about £950 each with the VAT, but that was before the pound drop.
Same treatment on the front struts.
A bit of open heart surgery on the front section :(
Excellent work , nice to serious resto work underway . I take it its is to be kept standard are you planning some mods?
Hi Henry, its going to be completely standard and original, down to welding up the new style window washer jet holes on the new roof panel and re-drilling to suit earlier type.
Front A frames reconditioned.
and rear spring plates
Great work. Can I ask what you used to recondition the trailing arms, front a frames etc? Which plating kit did you use?
The plating kit I used was this one http://www.classic-plating.co.uk/images/Zinc%20-%20Pro.JPG
The A frames were powered coated, the front struts were spray painted at my local spray booth.
Here is the steering rack,
Turbo tie rod kit was used on the rack.
Many thanks. Looks like a good kit. Great gearshift restoration too :) Unfortunately, I don't have a local powder coater so I'm going for the prime & paint option on pretty much everything. Not as durable but it speeds up the process and I like painting bits.
I am really happy how the hand brake came out.
Hi Mark, lot of work going on there, I think I got off very lightly with mine.
you say narrow bodies are rare, are they ?
who is doing the welding as I see a few VWs in there too, it's what I used to do, restore buses.
Yes you do need big pockets, yours much be huge...
Ron
HI Ron, thanks for the comments, do I think narrow bodies are rare? it depends which way you look at it, I meant the whole package, RHD 74 base model in Sahara beige (it would be nice to know if any one has one in same colour same spec).
A guy in Northampton is carrying out the work, as you can see his main business is VW vans and Beetles.
Inner rear wings repaired.
Errr, those kidney bowls are on the wrong way around or they're of a design i've not seen before. The sill would not mate to that correctly.
Yep, they're on the wrong sides of the car. Should look like this.
