Wifi endoscope app recommendations
Fuchs915
I have just stumped up for a wifi endoscope, however the app they recommend - moqo view - doesn't seem to want to work, opens then closes almost immediately.  I am trying to use this with my iPhone. Any recommendation for an alternative?
Kevin
I also use WiFi view, if only because it came suggested with my endoscope :-)
Works fine -  the biggest limitation (after user incompetence) is the endoscope itself, not the app.
Peter
Thanks all, especially Richard and Peter.  No Chris, it's for car stuff.  Honest.  Still haven't been able to get it to work with the iPhone but have been able to get it to work via USB on one of the laptops, so will give that a go.  A bit cumbersome but it works.
  • 2 years later...
How to setup the endoscope on ios version 13.4
i can’t figure it out
i was using moqo view app then when I tried to use it it wasn’t working so went to update the app it didn’t update then went to App Store the moqo view app it’s not available there.
I’d appreciate it if somebody could help me out With this  problem
My endoscope came with a recommendation for an app by wohler, a German company. It works very well on android, essentially you are linking the phone to the endoscope as if it was a wifi source.
When it's working the endoscope comes up as a wifi source under connections.
I had a look and there do appear to be iPhone versions - I recently moved to an iPhone but am still using my old android phone with the endoscope because the feckin' iPhone is so expensive...recommend the same setup if you have an old android smartphone lying around.
HTH,
Al.
On 11/17/2017 at 4:20 AM, Wingnonut said:
Kevin, I use WiFi View and it works with my endoscope on iphone and iPad really well.
I installed wifi view app when trying to connect to the my wifi endoscope unit what do i use for the ssid & password in the settings on the wifi view app settings?
  • 2 years later...
