Sign in to follow this
mascot100
Misfire on pick up below 2000rpm?
Went to Goodwood Fos on Saturday - 911 ran faultlessly there and back. Went back on Sunday with son on board - engine started to hesitate below 2000 rpm  on take off but ran perfectly after that and idled perfectly! Quite intermittent - on previous cars I'd have said plugs oiling up - but no sign of smoke or anything else. Car pulls like it it should once the coughs and hiccups have cleared.
Where should I start - plugs, leads, air mass meter - or something else?
Look forward to your collective wisdom.
Hi,
  Start checking the high tension ignition first; sparks , lead and distributor cap.
  Next,remove the near side rear wheel, looking at the up at top bell housing , is the sheathing for the speed and reference sensors damaged?
 Then check fuel injectors "chattering" using a stethoscope.Is the petrol clean?
   If this has not found issue, then further tests; check fuel pressure,vacuum leaks,Head temp sensor resistance,then Afm.
5 minutes ago, angusb said:
Hi,
then Afm...Also check throttle position sensor.
