Beaky
SSI's and footwell blowers
Hi People, hope everyone had a good Xmas.
A quick question, when fitting SSI and deleting the engine blower, I believe (and I could be wrong) there is a way to wire in the footwell blowers to help in the heated air circulation.
If correct anyone have the details?
As a side question I have noticed that since the engine rebuild, SSI etc. the car seems to be running hotter than before is this normal or just be being paranoid :unsure:
Actually the motor running hotter according to the gauge, or feeling hotter in the cabin?
SSIs chuck out tonnes of heat so I think the latter.
The gauge now sits at the first marking (8 o’clock) always thought it  used to sit lower.
Anil, thanks for the link
Sounds more correct to me :twocents:
If you still have autoheat the link Anil posted will sort you out, I ran with that mod for some time.
If you have backdated your heating you need a different approach to switch on the blowers, I can not find the post were I detailed doing this on my 3.2, but basically I spliced into the footwell blower activation wire and used the redundant rear wiper switch to make them manually operated at full speed only.
I only switch on the blowers to clear the front screen when I first start the car in the winter, after that they are not needed and the heating is more than effective without the footwell and engine bay blowers.
Hi Mark,
I have had SSI fitted, rear fan delete and all new ducting from an earlier model fitted, so is that autoheat and full bcck date? here's a picture
Autoheat thingy, now I have the answers👍
Edited by Beaky
I backdated my heat with some old twin levers between the seats and they have a micro switch on them which engages when the levers are lifted.  I don’t know what year it was from but assume pre SC.
But then....
Paragon had a genuine all original super low mileage 3.2 Speedster in a while back.  It had manual levers between the seats.   Wonder how it operates the footwell blowers?  Same micro switch?
Yes, cabs had 2 levers all the way through ib years, I would think yours is from a 3.2
I've also removed the ugly heater control box and backdated to the manual levers. When the levers are pulled up, the micro-switch now enables the footwell blowers on their "middle" speed setting, which delivers more than enough heat from the SSIs to clear the screen.
I was under the impression that the Speedster had the backdated manual levers but didn't have footwell blowers fitted, as per the Club Sport.
Interesting.  I would have thought that an open top car would need all the help it could get for heating.
So how do Clubsport and Speedsters switch the rear heater fan on?
