915 gear stick diameter
On ‎1‎/‎17‎/‎2019 at 9:55 AM, GaryH said:
Hiya Secret Squirrel. OK have some dims for you.
Outer diameter of the round bit - 90mm
Inner diameter of round bit - 85mm (2.5mm Wall Thickness)
Overall height - 94mm
Height from front (bit of the foot that's just in front of the round sticky up bit) to top 79mm.
I'll do a sketch in a bit.
Any other dims needed?
  • 2 years later...
Hi folks, can anyone tell me the outer diameter of the top of the gear stick OR the inner diameter of the gear knob? I'm having an aluminium gear knob drilled out to the correct size assuming there will be a new crush clip being inserted.
Many thanks!
Many thanks!
I believe the gearstick is the same diameter its entire length so you can just measure the bit you can see.
As Phil said, same diameter all the way up.
I'm sure it's 15mm
