James911SC
Oil change then clouds of smoke
Just had my first annual oil change on the SC (used Mobile 1) and I turned North London into something out of the Blitz!
I've never seen so much smoke coming out of the exhaust - ever!!
I hope it might be a spill on the manifold/exhaust and that a good blast up the dual carriage-way this weekend will clear it
But I've got a sneaky feeling that doesn't sound right - esp if it's coming out the exhaust
Any advice?
Did you fill it to the level with the engine running or switched off?
If it was not running you've over filled it.  You can syphon some back out the oil tank and set the level when it's running.
How much oil did you put in?
Overfill or too thin oil.
I did that when I first got mine or to be more precise the PO did before I drove it away! I'm sure it is a simple overfill. As Lewis says drain a bit out, go for a drive, get it warm, check the level again and you'll be fine. Any excess oil in the engine will burn off quickly enough.
Thanks guys - im going to check if the motor was running when they put the oil in and go from there
Ahh, so you didn’t do the oil change then....
Check the dipstick with the engine off and cold. If you can get any oil level on the dipstick its been over filled
We took some oil out and now I've got the SC back again thanks again everyone
They filled it on a cold engine 😱
I've learnt my lesson!
Good job, easily done.
Good stuff. Contrary to normal thinking right the IB fill up. Check when hot and running. Wtf. Surely could have used a longer dipstick to get a cold static reading?
Now what oil did you use? 😂😂😂
Suggest you find a new specialist ASAP
On my 3.2 I find roughly 10 litres after an oil drain and filter change gets the level to where it needs to be.
IIRC the total oil capacity is somewhere in the region of 13 litres.
What I do is drain into a 15 ltr bucket and empty into the previous oil change containers, then you put in the same amount as what came out and take it from there!
I don't think I would let those guy's loose on my car again!
Many years ago following stock car racing, we use to carry out body repairs on a number of write off's, had a celette churchhill jig so knew everything was straight, anyway one car we did was an almost new a MG Metro which needed a new front end with less than a thousand miles on the clock, it was a non runner so dropped the engine repaired the front end and put it back together, started it up and clouds of white smoke, after a lot of investigation took the head off as suspected head gasket put it back together and still lots of smoke.
After a number of hours did an oil change and guess what no smoke! the oil removed was as new but appeared thin, what we suspected was an oil change was carried out with incorrect oil and either the mechanic or the owner picked the car up and on driving looked in the mirror at all the smoke and went into the car in front! and then written off.
I have lots of story's like this, seems we got a lot of the dud one's but can laugh about it now
kev
Wow James
Just noticed the size of the air condenser on your car, is that oe Porsche or after market, must make it reasonably cool in there the turbo is half that size
kev
@Kev tbh I'm not sure - it was an US import so probably fitted by the dealer - there's no mention of air con fitted on my CoP.
I had it disconnected but this is something I bitterly regretted last summer Lol.
If I was going to do anything I'd get one of Jonny's fitted 😎
Mobil 1
58 minutes ago, James911SC said:
Mobil 1
Sorry mate. Bit of a running thing on here oil threads. Everyone has an opinion on which oil to use and we all kind of raise our eyebrows when a new oil thread starts (not that your thread fits the bill).
In all seriousness though, I would look for a specialist used to working on these cars. Schoolboy error that by your local garage and shows they are ill prepared to work on your car. Just my opinion of course.
