Sign in to follow this
Phill
Oil pressure warning switch removal
I'm going to change my oil pressure warning light switch (the one at the rear of the engine) as it is leaking.
Has anyone got any safety tips like the switch at the front which you shouldn't remove without it's mount because you might crack the block?
to remove the oil pressure switch i used 2 10cm 1/ 2inch extensions.With 27mm socket on the end.Before remove the airboth so you can get a ratchet on the top of the extensions.Once is loose i used a rubber hose which i pushed on top of the switch and then unscrewed it.Same procedure in reverse.
Thanks Ivan. I have clear access as no CIS.
Right, I have done this. It came undone quite easily but I established it wasn't leaking. I replaced it anyway as I had one on the shelf.
The leak was/is coming from were in have placed the knock sensor. The oil is travelling up the bolt thread and out. So can anyone recommend a thread sealer. This one seems to be right?
https://www.amazon.co.uk/Permatex-59214-Temperature-Thread-Sealant/dp/B0002UEOP0
Still a leak. Pretty sure it's the thermostat cover now. New o ring collected from Matt. No CIS makes this all easy to do 👍
Right then. Undid the two nuts but the cover will not budge. Is it straight lift off? It can't twist because of the studs. Am I missing any special Porsche oddity?
Ivan? @proporsche
From memory there is a lip set into the rim into which a screwdriver blade can carefully inserted to pry the stat upwards.
That's helpful, thank you. Did try it but probably need to lean on it a little harder. I didn't realise the stat came with it!
Pinched off Pelican, in the photo with the stat out off the engine you can see the pry slot formed by gradual reduction of the lip/rim depth. The first photo give you an idea of where this slot is relative to the car. Enjoy!
hi he studs are there and cannot be removed with the engine in the car on 911SC....Then you have top lift the el.harness.  and possibly the breathing hose migh be in the way...
on the picture somebody had bolts in not studs..
Thanks Ivan. I think I just need to be a bit more brave with the prising up.
i just hope you do not have these air line there too...these alu. lines
Bi Phill
Also check where the breather hose attaches to the crankcase.  The failed gasket under mine was the culprit for most of my escaping oil, which then pooled around the oil switch.
Peter
None of that Ivan. I don't have any CIS left.
43 minutes ago, PeterK said:
Bi Phill
Peter
I'm not Bi Peter!!
New gasket intended with Hylomar Blue for added measure.
I have, however, trimmed the breather hose itself which was a bit stretched. That may solve the issue and I shall wait and see before trying the thermostat again.
1 minute ago, Phill said:
I'm not Bi Peter!!
Sorry Phill - typing by Fat Fingers again (or was it Apple's spiel chucker) !
Having been for a spirited drive I checked the triangle of death and found more oil. It certainly looked like it was coming from the thermostat housing this time so I bought one of these (glasses for scale).
This time the stat popped out easily. I think possibly loosened by my last, unsuccessful, attempt.
The o ring was certainly crusty and flat. New one fitted, stat refitted.
Now I'm concerned I put it back then right way round! I'm fairly sure I put it back the same way but these things nag at me (mild OCD). Can it go in one way only or do I need to take it out and check?
Found the answer. It can only go in one way round :signs85:
