How much are a pair of 8" Fuchs Reps worth?
Busybee
1 hour ago, Busybee said:
Thanks SP. Figured around that.
Can original centre caps be made to fit these?
I had to make some up to fit mine Haith.
The bit that pushes in, then rivet/glue the outer bit onto it.
I just bought a 9” wheel rear off Matt for £200 delivered. I suspect they’re the same type of copy wheels.
Russ
Edited by Rustybum
Russ
Thanks Russ. Remember you saying before. How did you adjust or make the centre piece to glue the top onto?
Think I’ll have the pair of eights. See how they look. If I like them I’ll keep them, if not, move them on.
Haith
Not sure I would be happy with glue on a wheel that could get hot from the brakes...:unsure:
Understandable Doc. Can the existing centres be adjusted to fit I wonder?
I used the original rivet/peg things with the clips on and then used an adhesive. Similar to tiger seal, just to add extra strength.
They're fine.
They've been in for quite a while now and not had any problems.😊
I looked at that but I didn’t have a lathe big enough to fit the wheel onto.
You could try drilling, grinding it but getting the hole centered properly would be difficult.
I just used a former (a big old socket) to beat some steel around, then drilled for the rivet holes and clipped/bonded the outer part of the cap on.
I have chemical metal on a couple of mine where the rivets have failed and they have been fine for years.
