SP72
Instrument gauge rubber gasket ring tings
Any particular brand to go for?
Dansk, Partwork.de both do them or genuine only?
Mine may ‘go again’ but are covered in hardened grease, slightly stretched and torn in places so looking at new for circa £50
Also, is silicone spray recommended on the seals?
Thanking thee, ta
I would go genuine for anything rubber and use silicon annually as a preventative measure on door and boot seals.
Thanks Ian
Genuine £125
Aftermarket £55
911 641 902 01 100mm x2
911 641 903 01   115mm
911 641 901 01 80mm x2
I used Vaseline on my gauge rubbers. Lovely jubbly
Yup, all 5 in both cases.
59 minutes ago, Type911 said:
Give me 24 hrs
Cheers dude
May not be so lubbly on removal - mine were removed 5 years ago when refurbed by reap - couldn’t believe how much force was required to remove them again recently. Unsure what was used to lube them though
Can’t have been Vaseline SP 😂
41 minutes ago, Ian Comerford said:
Is that for a or a full set, all five?
I don’t think £125 is bad for a full set and the fit on original Porsche rubber is usually better
Is that £125 for the 5 o rings to fit around the gauges?
Maybe  - they’ve lasted 30 years I guess.
that be they - aftermarket here - https://www.partworks.de/en/partworks-de/Assemblies/Set-rubber-rings-for-Porsche-911-G/964/993-speedometer/instrument-cluster.html?listtype=search&searchparam=Rubber ring
Edited by SP72
Looks like the rubbers for 911 up to 1985 are available from Dansk but about the same cost as Porsche that is £6.60 per piece so about £40 inc vat (00 numbers)
They change on 1986 to the 01 number (I cant work out why?) These seem to be Genuine only and work out about £105 inc vat for the 5
I would buy the 00 ones from Porsche and I bet they would work a treat!
Aftermarket ones listed for all 911, 964 & 993 are the Dansk 00 ones BTW
Thanks Matthew
No change in gauge size iirc?
I may have a -86 clock with gasket in the lockup I can compare to.
I’ll be in touch re a Rennline phone mount too.
Gauges didnt change, dash cover didnt change either
2 hours ago, Type911 said:
Gauges didn't change, dash cover didn't change either
Sounds like Marketing and Accountants at play...............................pretend its changed and ask for more!.
Ended up ordering new ‘01’ items from Porsche but here is a pic of a ‘79 dial - be interested to know the difference with the earlier rings:
