ALEX P
Hidden speakers
I want to fit some hidden speakers, maybe under the dash. I refuse to cut holes in my doorcards so before my car became luxurious with carpet and sound deadening I cut holes in the sill blower covers and mounted a pair there for a bit which kinda worked ok until I put the sill blowers back in and then there wasn't really much room for the speakers.
I've got an underseat sub (which I haven't yet fitted) so probably only really 'need' mid & tweets but don't mind fitting coaxials or whatever really. I don't want to spend loads of money and it's never going to sound great because my car is noisy but when I think about what you can get out of tiny ipod docks these days or little bluetooth speakers then there must be something half decent that fits into a small compromised area....
Any ideas?
Just using a bluetooth speaker doesn't appeal then?
One of my door speakers has been kaput for a few years. A noisy exhaust makes it all a bit academic doesn't it...
What about the rear shelf?
I upgraded the ones on the rear shelf with new covers and didn't bother with any after replacing the door cards... not perfect but works well enough
What size of speaker did you originally mount in the blower covers?
I was hoping I could use a pair of 3.5in speakers (with a spacer if required) in the sill covers to prevent cutting holes in my new RS door panels.
Just need to find a pair that come with acceptable looking grilles.
Any ideas?
facing down from underneath the glove box space? using that space to help as a speaker box
Not the answer you are looking for....
If you can bring yourself to cut holes in your door cards you get a suitable mounting location to make the most of the challenging acoustic shape of a car. I fitted elasticated net door pockets over these. Great for toll tickets or track day documents. Photo's clearly show the speaker but in the real world, they are quite hidden.
Not really. I've got one of those VDO head units with bluetooth so just want some discrete speakers. The noisy exhaust means I'm not chasing audiophile pleasing sound. Just want to play some tunes and run my phone through the head unit.
I don't have a rear shelf as such anymore. I put an RS-ish carper kit in there and added rear seats on top. Same applies for the rear quarter cards, they're just carpet now.
Yep, two speakers would be fine for me too. Just not on the rear shelf.
I just transferred my old door speakers so they were 5.25" or 6.5" I think. I've stuck a photo at the bottom of this.
That's the sort of thing I was thinking of. I know it's not ideal that it's pointing at your feet but there looks to be space to fit something there. You can get tiny speakers that belt out sound these day albeit at the expense of any bass but that can be taken care of with the underseat box.
That's quite a neat solution. Can't bring myself to cut up the cards though :cry:
Probably a silly idea but what about using something like a Bose revolve speaker from your phone? Easy to get a 5v supply to and ours works well at home so may work in the car?
Alex, I have a pair of 'Ultimate ears' Wonderboom bluetooth speakers. Deeply impressive for their size, so perhaps the larger 'Megaboom 3' model mounted against the bulkhead forward of the gearstick? They are USB chargeable so you could arrange a switched supply to charge it although it's only audio input is bluetooth, so you would have to pair it with the head unit and your phone. For even more discrete location, try same place but higher up behind the ashtray.
Something like that probably would do the job quite well but I think I'm just going to try sticking some small (maybe 3 - 4" speakers under the lower dash pointing at the floor, maybe mounted on a bracket or plate.
If it sounds rubbish then I will either live with it or come back to one of the suggestions above.
Thanks for the replies chaps.
I think you’ll struggle to find enough depth for any speaker under the dash.
I can’t recall another car where the front bulkhead IS the underside of dash.  It’s a real pain for a lot of stuff like this.
All speakers no matter how tiny require being in a sealed box or else the sound coming off the back largely cancels the sound from the front as it's out of phase. This is most heard in the bass frequencies where the sound is more omnidirectional. ie. tinny little speakers will sound even more so when not in a sealed box.
Sorry to hijack the thread but I am looking to change my speakers too, but as the cards are already cut will do a like for like change. They are 6.5" speakers. Has anyone done this recently and any recommendations out there?
I just fitted a set of cheap and black 6.5” pioneer 3 ways in my SC (had metallic orange Edge speakers in there before which were just gross). I’m really impressed. For under £30 delivered from eBay, they sound amazing. Not b&o or Bose quality but in a noisy IB, fab.
Price looks like it’s gone up but you might find them a few quid cheaper. I paid just under £28 for them delivered.
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F113233994167
Cheers Haith, have found loads out there, but wanted someone with real world experience. Thanks.
👍 you can’t really go wrong for £30. Just make sure you screw them in nice and tight and you’ll be amazed by the sound quality. Grills were a fiddle to push in but just take your time. They’re a bit flimsy.
Have you seen this thread @ALEX P? http://forums.pelicanparts.com/porsche-911-technical-forum/949395-show-me-your-stealthy-speaker-stereo-install.html
I want some tunes in RB’s old car, now my new car. It’s loud though and I love the headless look. Kind of fits the car. Something that I can run off my phone would be cool.
Shirish has hidden door speakers. Just a few holes in the door card with the speakers mounted behind the card. Pretty stealthy especially with black alcantara door cards.  I just wonder how useful speakers in the traditional sense would be in loud cars.
Maybe a really good set of in ear Bluetooth headphones are the way to go and cut out the in car stereo all together. Anyone use those? .
The Pelican thread is interesting Haith. Those Moch-1 under dash was the sort of thing I had in mind but I doubt they cater for RH drive cars and would probably cost a fortune to ship over if they did.
http://www.moch-1.com/UNDERDASH.htm
I've seen SP's door cards & they are nicely done but I'm leaving my cards as they are. I've never really liked the idea of driving with music playing earphones in. Not sure what the legalities are, I mean deaf people are allowed to drive but that's not the solution for me.
Right now I'm thinking of an under seat woofer (because I've already got one) and some flat midrange/tweets. I'm not looking to spend lots of money so was looking at these Pyle sunvisor jobbies but I would just stick them on a surface under the dash area not on the visors.
http://vi.raptor.ebaydesc.com/ws/eBayISAPI.dll?ViewItemDescV4&item=372693864485&category=179671&pm=1&ds=0&t=1563016484790
https://www.ebay.co.uk/itm/172590620512
