Anil
Oil Tank Refurb Help
I've finally removed the oil tank in order to attempt a refurb i.e. clean back to bare metal and repaint.
Most of the paint flaked off easily with some gentle scraping, but there are some areas of thicker paint that seem really stubborn where the scraper and the wire brush attachment on my drill don't really do much. Pics below show what I'm currently left with.
Just wondering what others have used to safely remove the paint prior to refinishing the tank?
...Or is there someone out there that offers an oil tank refurb service that would undoubtably do a better/quicker job of it than me !
Just get it sand blasted. Probably cost you £25 if that.
Edited by Phill
I stripped mine back to bare metal on the outer face and the seams but found the inner face was perfectly ok so left it. Keyed up the edges of the existing good paint and overlapped it with the new paint. I use a prep wheel (screwfix) and some emery cloth. The prep wheel will remove paint alot easier than a wire wheel.
I treated any rust with fe123, then two coats of bonda primer, then two coats of rustbuster epoxy primer.
After it was finished I sloshed it through with petrol.
Looks like you've done most of the hard work already!
I wouldn't get an oil tank blasted. You just cannot guarantee that no media will get inside however careful the guy blasting it is & you are never going to be able to guarantee that you get it all out so you may as well stick it in the bin at that point.
From your photos It doesn't look that bad to get off. Wire brushes on drills only get you so far. You could gently use a cleaning disk or a flapper wheel on an angle grinder on the nice easily accessible open faces or you can get some fairly nasty paint stripper (not the pansy B&Q stuff) that would get that off pretty easily.
I had mine sandblasted and then chemically stripped inside. As long as the openings are sealed up well there will be no problem at all. Everyone on here worries so much I'm surprised they leave the house, let alone drive their cars :P
:smiley-good-post-sign:I've not been outside without adult supervision in years
With the right combo of pads and tools you can get them clean enough without blasting.
No way would I ever get an oil tank blasted, no wonder your head studs popped Phil :)
I managed to get mine to look like Jevvy’s with just a wire cup brush  On a drill and some scotchbrite pads. Then painted it with Rustbuster 121 epoxy mastic. Still looks good under there.
Phill runs with scissors........................:blink:
Walk under ladders and kick black cats that have the gall to cross my path!
Thanks for the feedback chaps.
I wanted to avoid blasting hence the DIY route. I was also keen to remove all the old paint just in case there was any hidden corrosion, and I don't want to be doing this again.
I don't have an angle grinder so a drill (or dremel) attachment will have to do.
Impressive work Jevvy ! That's the finish I was aiming for. You don't offer a refurb service do you ? :)
So, checking on Screwfix, I see the following drill attachments which may help:
https://www.screwfix.com/p/titan-abrasive-flap-wheel-80g-60-x-30mm/78877
https://www.screwfix.com/p/surface-preparation-wheel-with-arbor-100mm/31074
https://www.screwfix.com/p/norton-expert-wire-brushes-3-piece-set/7944h (the 25mm brush looks useful...)
Anything else I may need?
The bottom two links are what I used, prep wheel and wire brush for the awkward bits.
Fe123 Rust treatment from rustbuster or something similar.
Primer
Top coat
IMO an angle grinder Is a must have tool. Makes life so much easier for all sorts of jobs.
Doh! Posted at the same time as Nige. Do what he says....
4 minutes ago, Nige said:
40 grit discs :blink: are you sure you just want a pile of steel filings or a clean oil tank
Just use wire wheels ideally a cupped one on an angle grinder as others have said , wouldn't  bother with the flappers , may be able to  manage with a decent drill ideally  mains with a bit of power and rpm . Plenty of advice here  🤣
Don't they have 80 grit listed?  Just don't press on so hard!
I like the clean and strip discs, I've found them really good at this type of job.
only 40 listed, it's a tad aggressive at material removal
my left wrist looks like I've had a go at a suicide when a 40 grit disc bit me
wish I hadn't pressed so hard that time too :o
Agree 100%. 3M clean and strip discs, available for drills or angle grinders. Rips the paint and rust off without harming the metal.
Thanks again for all the suggestions.
Popped into Screwfix this afternoon and bought all three of the wheels/brushes I listed above.
The Surface Prep Wheel (which looks like the clean and strip disc recommended above), used with my drill, worked perfectly to clean off the remaining paint/surface rust very quickly, and I used the 25mm wire brush attachment for the bits around the tank brackets. Not quite to Jevvy's level, but the tank is now paint free and ready to prep for the primer/mastic.
I will be buying a few more of the Prep/Clean & Strip discs in various sizes for other projects as they worked so well.
Good work Anil.
I've been using these quite a lot recently and really like them. They flare out with RPM which really helps get into nooks and crannies without taking any metal off which some abrasives can do.
3M-Scotch-Brite-Roloc-Bristle-Disc-RD-ZB
They last quite well too as long as you are careful around sharp edges. I mainly use them with the air tools but also bought a mini die grinder / angle grinder thingy for when I cant be bothered to fire up the compressor or trying to make a bit less noise.
https://www.aimtools.co.uk/products/katsu-hobby-art-mini-electric-special-narrow-places-angle-grinder-3
61OxNn-JH5L._SL1000_1024x1024.jpg?v=1544
Looks a bit budget and is super cheap but I've given it death for hours on end and its still going strong. Needs an adaptor to fit the 3m bristle discs which can be found on ebay but then you can use any roloc disc type on it which makes it quite versatile.
