Sign in to follow this
mean in green
Handbrake winding adjuster question?
A quick check please - the winding handbrake adjusters that are accessible through the hole in the rear discs... say that you were viewing the toothed adjustment cog from directly above, clockwise “expands” the shoe position right?
yup but before you should adjust your cables..then adjust the the wheel and 3 clicks back
Ok thanks. Think I’ve over adjusted it one side, feels like it is dragging very slightly when I push the car on the drive and the wheel is warmer than the other side after a short test drive.
that is the reason i tell peeps to adjust the cables 1st and then the shoes plus 3 clicks back necessary...
