scuttle electric connector
Hi, the little "daisy wheel" leccy connector that is tucked up in the scuttle on the nearside wing - whats the best way to remove it? Push through so it comes out in the trunk or pop it out into the scuttle/wing side? I just need to get access so i can reconnect the receiving connector. Not an easy job in situ.
Many thanks
Will
Hi Will
Hope you are well?
Do you mean one like this but with the wiring going straight into the back of the plug? If so heat up rubber with a hair dryer and push out whichever way is then easiest to push back in.
Cheers Nathan
