Seized bolts in Spring Plates
Brads
I am trying to replace the spring plate bushes but having nothing but trouble. The bottom through bolts that attach the plate to the Swing arm are seized solid, I have managed to remove the nuts but the bolts are solid in the alloy arms and won’t budge.
I have tried heat but afraid of putting to much into them for fear of melting the alloy. Any suggestions please?
Have you removed the "stop" bolt, then lowered the trailing arm fully?
Removing the old bushes from the spring plates is fun! Enjoy.
If you want a set of neoprene bushes (lots of debate here about rubber Vs Neoprene) I have a spare set in the garage ready to go.
Chris.
This is good stuff, we stock it but every ECP should have it, made by Wurth and rebadged
  • johndglynn changed the title to Seized bolts in Spring Plates
