Fuchs Center caps
BigG
Hi all,
Can any one help me on the following
I have purchased some Fuchs 15s and now need the Center caps , what are the original ones and genuine ??? Some caps have x2 wholes in them and others don’t . None seem to have part no. On neither . I have a 82 Sc 3.0 targa. So would like the correct ones for the year.
any help will be grateful
cheers big g
You need the correct ones for the wheels, not the car!, what is the internal diameter?
Hello  type 911
Thanks for reply.There 70mm Int.diameter.
Your wheels actually have a 71mm hole, early version didnt have the 2 holes (there to remove easily with a special tool or wire) they all now have the 2 holes in them, like these
1 minute ago, Ian Comerford said:
Never use the end of a tape measure if you want accuracy.  Go from ten cms in and then don’t forget to subtract that amount
+1 :signs85:
If you want real accuracy don't use a tape measure use vernier calipers.
Thanks again for your help
  • 6 months later...
