Mileometer and Trip stopped working
On the way home I noticed my trip and mileometer stopped working.
I assum its the internal mechanism as the speedo itself still works.
Is this a easy DIY or is this one for Reap?
That's a good thing isn't it ;)
Got to be DIY I'd have thought. I have an article on how to do it, I'll try and find it.
Mine did this a couple of years back. The grease that was applied to the worm drive during assembly spent the last 30+ years turning the plastic gear into jelly.
Easy DIY repair once you get the bezel off the gauge.
Gears are readily available via eBay or a chap in Cornwall - don’t remember the name of the company.
The replacement gears don’t need grease.
That Blonde moment when you realise you just took out the Rev counter and not the speedo!.....................................................
Great!  But at least you didn’t start to strip it.......or did you?
Nope, on the upside it made getting the speedo out a lot easier!
  • 7 months later...
Hi guys, I know this is an old post, I have also encountered the same problem, odometer is not moving but speed reads fine. I took it apart just trying to see if the gears are indeed broken, turned out the gears are all fine, mileages moves when I turn it manually from the first gear. Now I wonder if I can get a replacement for the odometer motor?
Many thanks,
JT
Edited by Justin689
