16" Fuchs losing hub caps!
After tyre changes I have lost first one and then a second hubcap from the left side 16" Fuchs following spirited drives. I checked all three after the first departed and they seemed tight, but.... I have replacements, but is there some trick to their installation other than just to press them in? I do not want to lose more.
SOW 911 038 11    Hub cap Black Crest Coloured
Strange, they're usually really snug.
You could try tweaking the retaining ring outwards a little so they grip more firmly?
Wow! Thats expensive! I would use some clear silicon on the inner ring.
Years ago we sold these locks
Hi Matt ..i suppose you do not these any longer?
There are three retaining "bumps" on the collar of the centre cap that that make it a tight push fit, these can wear down a bit making them lose. If you take a centre punch and reform the "bumps" by tapping on the inside of the collar in the corresponding indents it solves the problem.
