Rod bolts (again)
PeterK
So .....
Using Wayne's engine book & the Bentley manual, I have torqued my new rod bolts to 20Nm, then turned through 90'.   Now while looking for sealant info, I read that that 20Nm+90' is wrong (maybe as high as 75Nm, and too close to the yield point of the 10mm bolts) and I should have just used 50Nm.
A new set of nuts & bolts from Porsche is just over £325 (ouch).
Options
1 - just carry on with my rebuild - many people will have used the 20Nm + 90', so it can't be that bad (can it ?)
2 - pay Porsche £325 and suck it up
3 - buy a cheaper set of bolts from one of the well know vendors (about £125, but provenance unclear)
4 - buy ARP bolts & nuts (no idea on price, but would need to buy / make / borrow a stretch gauge)
5 - something else.
Please discuss
No need for ARP on a proper engine 😇 but at £325 for standard, ARP are probably cheaper !
Isn’t the other option (I could be totally wrong) Porsche 993 turbo bolts as these fit as strong  as ARP’s - not sure on price
Edited by Beaky
Are you thinking of head bolts Beaky ?
Edited by GaryH
Could be, I just remember in my engine rebuild research turbo bolts were an option for something!
The proper (SC) engines had 10mm rod bolts, but from 3.2 Porsche went to a 9mm rod bolt.
Head studs guys, studs, black fully threaded are dilavar, steel arent fully threaded
Easy enough to google "black 8" stud"...................................then go to images and see :blink:
Ha ha - back in the day we used to tell new people at work that we were out of pens and they should go to Pen Island dot com for replacements :lol:
You're a naughty boy, Mr Matt 😂
In my youf it was send the receptionist to the motor factors for a water pump for a Beetle, a long stand or a bucket of steam.
On 30/10/2020 at 16:30, PeterK said:
So .....
Options
5 - something else.
Please discuss
If you've got new rod bolts (12.9) and new nuts and youve done it IAW with what you've detailed. Option 1.
Don't over think it.
I went through a similar quandary on rod bolt torques when I did my first 3.2 rebuild. I probably did overthink it, but you may find the info in my thread below useful:
Thx
So overall, just crack on with my build 👍
Thanks all.
Although I am almost certainly OK, I’m wimping and replacing the bolts.
Anyone need a set of nuts & bolts, tightened once but never run 😂
4 hours ago, PeterK said:
Thanks all.
I don't know why you are worried, according to MaxD's link half the specialists in the UK don't know how to torque down the big end caps. 😃
5 hours ago, ras62 said:
The initial 20nm plus 90 results in 45 lb/ft which is correct, about 50nm. A little grease under the nut to stop binding.
A little grease ? I'm no expert but they should spend their lives bathed in oil.
Peter, you did the right thing in buying rod bolts. I was in a recently rebuilt 911 a few years back which had a rod bolt go, its not pretty but luckily happened at low revs albeit pulling onto a dual carriageway. I rebuilt it for them and used ARP with a stretch gauge, job done. It easy to be blase about these things until you hear an engine actively trying to tear itself a new one.
