Rear backplates stuck
craigt
I cannot remove the rear backplates from the hubs and am assuming it's corrosion between the 2 differing metals holding it on. Or am I missing something and being really thick 🤔
It's secured by 4 bolts that fix the bearing retaining plate which I've removed.
Anyone had the same issue or a solution?
It's been getting soaked in WD40 and heated on and off for days. If I go at it any harder I'm going to deform them.
Thanks in advance for any advice
Craig
I damaged mine getting them off, tried everything but ended up just hammering them off.
I'm pretty sure they weren't that expensive from Porsche, I'll have a look through my invoices.
Edited by Andy352
Addition.
Cheers Andy, I don't think I can get enough heat into them, the alloy hub must be sucking it up.
I hate destroying things but I think that's the way it'll go.
Hope you're well and maybe catch up after the year.
I tried to straighten mine once I'd removed them but they have to be perfect for the handbrake shoes to sit right. My invoice says £64.50 each but they sent me Turbo ones by mistake and then swapped them so don't know the actual price.
We'll surely manage a run next year!!!
It was around this time last year we were planning a run in 2020🤣
Fingers crossed
I'll break oot the big hammer tomorrow😁
53 minutes ago, Type911 said:
£67.82 from OPC
Thank you..... OPC Edinburgh who are always really helpful just confirmed that. Plus VAT but I get to wander round the showroom
45 minutes ago, Boydyrs said:
I’m in don’t forget me?
And me!
Give me some notice - I will need to clear a route to get it out the shed.
  • johndglynn changed the title to Rear backplates stuck
