What is this nut?
Phill
The nut on this part appears to be a j nut but without the leg, so essentially a "c" nut or half a speed nut. Anyone know what they are called? I cannot find one online for the life of me :(
91157105100-p17749-connecting-flange-pho
11 hours ago, Jonny Hart said:
Sort of a spire nut.
Btw on that part, the fixings are more like a caged nut on SC and earlier cars.
Yes, but not a type I can find, I think it may be a special production.
Yes, but it's a weak point (after 30 odd years admittedly) and the above design seems better.
8 hours ago, flappa2 said:
Google is your friend
Captive u-nut
Trust me, I searched! It is not your standard type of u or j nut etc. I cannot find similar at all.
Could you modify something yourself from a stock part or even make an item. I'm not familiar with the part, what's more important the function or the original form.
4 minutes ago, PorscheApostle said:
I looked at j nuts but there isn't enough room for the long leg on the side you can't see. A short chimney but may do it.
However, it is a moot point now as I found another reason I cannot make this part. PLA won't take the constant heat passing through it during the winter. Oh well, grand plans and all that.......
7 hours ago, Jonny Hart said:
^ for reference, I have measured temperatures of just over 100 deg C inside the heater ducts.
Wow, its amazing people don't get burnt feet 😂
What’s the most heat resistant material your printer can handle Phil ?
PLA is pretty much it unless I build an enclosure for ABS but even that is only really good to about 90 degrees I believe.
