I have a 1984 Carrera 3.2, ‘relatively’ newly acquired (given lockdowns) and so only refuelled twice.
I can see a piece of metal at the junction of the fuel filler neck and sleeve. This is stopping me inserting the fuel pump nozzle past this point.
Is this normal for these cars?
Edited by Jonny99
Normal, also best way to fill is to twist the pump handle around so its more vertical and the grip/lever side faces across the car rather than down to the floor like you would normally.
No it stops it from going further in, which is quite shallow to be honest.  The filler neck changes direction there quite acutely so I guess a petrol pump nozzle could get stuck if inserted too deeply 😳
Why should you use the fuel nozzle upside down?  What does that affect?  Have always fuelled mine normally and not had any problems.
I found you get air locks less by inserting the nozzle upside down. Our engines are in the wrong place anyway so it makes sense we should fuel them upside down.
  • Haha 2
Same as Les, just seems to fill up easier without the pump air locking and less splash back.
Our cars were designed before the advent of forecourt pumps with built in safety overfill cut-outs. Some pumps are just too sensitive and keep cutting out on our cars when used in a conventional orientation. Using the nozzle "upside down" stops the problem.
I find the trigger at the south west position and tilting up to the north east works for me. Depends on which way the car is pointing of course :whistling:
59 minutes ago, 16vjay said:
I must have been lucky with the pumps I've used I guess.
You must still have petrol pump attendants in Norfolk and a choice of 2, 3 or 4 star?  ;)
  • Haha 2
Yes, I'm close to having a Cortina's-worth of Green Shield Stamps!
