Turbo piston rings
Hi there.....maybe someone can help me?
I have a 3.1 sc-l from 1980 . The engine was factory produced using early turbo barrels, SC crank with high compression mahle pistons.
As it was a special run spares are no longer available. I suspect the ring pack  have the same dimensions as the standard early turbo, has anyone got a set of rings that they could measure for me?
The pistons and barrels are in good condition, I will replate and hone the barrels but I want to be sure to order the correct rings.
Many thanks in advance
Steve
Piston Ring kit 50367N0 by MAHLE ORIGINAL
1. M 1,5 IF, 2. M 1,5 IF, 3. GSF 4,0
Cyl.Bore  95 mm
Standard (97.00 mm) 1.5 - 1.5 - 3.5 mm
Thanks very much!
I'll get them ordered, any idea for the best place to buy, original mahle is best I presume?
