1981 3.0 SC 'Hot Rod'
Leicestershire
With other commitments and new projects, I need to start thinking about parting company with my SC.
Current spec:
1981 MY SC
1st Registered Dec 1980. Current mileage 99.7K
1981 MY Grand Prix White – Sport Specification – Registered Dec 1980 - should be TAX exempt after April 2021.
I started this project with the best SC I could find. The previous keeper owned the car for 17 years – entered for concourse shows etc.
Rust free shell, GRP front wings, steel frame ducktail, original style front and rear GRP bumpers on steel (front) / aluminium (rear) bumper mounts. Sunroof delete using welded in ‘wheeled’ steel panel.
Also available 3.2 rear spoiler & lid finished in matching white.
Bodywork repainted December 2011 with Deltron base and lacquer in the correct Grand Prix White (908).
Underside of the car has been refinished
Alloy under tray.
Engine
The engine development has been continual project over the last 10+ years. The first rebuild was to replace the head studs and investigate the condition of the internal components.
Upon initial inspection the engine was found to be still within manufacturing tolerance – hone marks on bores, cams & rockers as new etc.
Current specification:
10.5:1 forged Wossner pistons
Modified ‘S’ camshafts – GE40 profile
Hydraulic chain tensioners
RSR flywheel, Helix cerametallic paddle clutch (sprung centre) with lightweight alloy competition cover
Heads – large port / valve Euro spec 3.0 heads (39mm ports)
Designed to rev to 7500 rpm current build 244 bhp
1.5 inch stainless RSR headers
‘Crab’ Magnaflow 2 in 2 out silencer or a ‘quiet’ Dansk 2 in 2 out silencer.
40mm carburettors on magnesium manifolds matched to port sizes. Rain hats and ITG filters sit on top of the carbs.
Standard Bosch distributor modified with custom advance curve and springs to match cams
964 Turbo rear engine mount & polyurethane bushes fitted in all engine / transmission mounts
The engine tin has been replaced with GRP parts
Current output is 244 BHP
Other engine options available – 3.0: 200 – 270 bhp or 3.6 / 3.8 350+ bhp
Gearbox
The transmission is a 915 type fitted with a Gripper LSD – plate type
Wheels – 1 set 7 & 8 x 15 pressure cast hi-magnesium alloy 5 spoke – finished in satin gunmetal.
1 set 7 x 15 ATS cookie cutters finished in gloss silver
Brakes
Boxster (986) front calipers with DS2500 pads
3.2 rear calipers with DS2500 pads
930 master cylinder
3.2 discs front & rear
Goodrich steel braided flexible lines
Rebuilt pedal box
Oil / Cooling System
Mostly new oil lines with the exception of original front to back hard lines
Front mounted Setrab oil cooler
Suspension
All re-bushed using poly or neatrix bushes - except the front ‘A’ arm bush - this is a solid delrin type bush. New rear ARB drop links, Turbo front steering arms and steering rack spacing/bump steer kit.
Standard ARB’s and front torsion bars
26mm (Turbo) Elephant rear torsion bars
Standard front ‘green’ Bilstein sport legs
Rear - adjustable Gaz shock absorbers
Interior
Lightweight RS carpet set fitted
RSR ribbed rubber front mats
Momo Prototipo with a 20mm spacer
Porsche crest Motordrive composite seats – black
Motordrive seat mounts
RS door cards (old type with leather strap & fiat 500 door handles) with net pockets.
TRS 6 point harnesses
Safety Devices rear cage with diagonal and harness bar.
Heated front screen – green tint to match factory glass
Basic Nakamichi RDS radio with CD, door mounted JVC speakers and aerial hidden in luggage compartment
Sucro headlight relay
Original jack, spare wheel and tool roll
Cat II immobiliser & alarm system
2 sets of keys & immobiliser fobs (1 key for doors and ignition)
Viewing welcome once COVID restrictions allow.
This vehicle is offered for sale at £52,000.
