I've just acquired a Turbo ARB as part of a suspension overhaul and upgrade to replace my standard 22mm ARB.
One slight snag the "Legs" of the bar are slightly out of true; when sitting on a flat surface, one leg being 4/5mm off the surface.
I cant decide if this is a problem or not....
If it was a race machine corner weighted to within a kilo, obviously its a problem, but for swift road use, I'm not so sure.
Any thoughts welcome...
Front or rear? If it's rear the 4/5mm could be dialled out using adjustable drop links. If it's front it would be a no from me. However, being steel, I'm sure the right person could twist it straight again? Or, I think later G50 3.2s had a 22mm front ARB* should should be easy to source a new(er) one.
*can't actually find that info but I have seen it here somewhere. Silver WT or others will confirm.
Thanks for the comments Chris. It is a front ARB, so no adjustment or drop links involved.
Its a 25mm bar, so correcting could take some really long scaffolding poles...
May just be easier to bounce it back to the supplier.
AT
My apologies I read it WAS a 22mm not REPLACED a 22mm..... I wouldn't use a bent one, you will never get geometry spot on.
Are you sure it is 25mm and for an IB?
Have you compared it side by side with a known IB one? Or, is it a through the body version?
AFAIK there was never a standard front ARB above 22mm (Turbo or other), see PET extract (PET up to '89 only lists one 22mm for all) ...
Also, AFAIK, only larger diameter "through the body" type front ARBs  were/are available from after market suppliers.
But, yes you can fix it by bending it back if it's just a bit out. However, I would not do anything until you are 100% sure it is for an IB.
You mean this?
  Front TB Rear TB Rear TB Splines Front ARB Rear ARB Rear ARB Shape
>'77 18.8mm 23.0mm 40/44 16/20 mm ? Early shape
SC 18.8mm 24.1mm 40/44 20.0mm 18.0mm Straight
Carrera 84-85 18.8mm 24.1mm 40/44 20.0mm 18.0mm Straight
Carrera 86 18.8mm 25.0mm 40/44 22.0mm 21.0mm Straight
Carrera 86-89 (G50) 18.8mm 25.0mm 46/47 22.0mm 21.0mm Offset
Turbo 84 18.8mm 26.0mm 40/44 22.0mm 18.0mm Large offset
Turbo 85-89 18.8mm 26.0mm 40/44 22.0mm 20.0mm Large offset
Turbo 89- 18.8mm 27.0mm 46/47 22.0mm 18.0mm Large offset
You mean this?
Thanks for the PET extract on ARB dimensions, good info.  Its certainly is an IB item, profile is a mirror of my standard ARB. Must be aftermarket in that case.
3 hours ago, Ian Comerford said:
Unless you can straighten it and be sure that it will function consistently across its length I wouldn’t use it.
I'm leaning to your way of thinking also Ian.
Best pack it up and ship it back..
42 minutes ago, mean in green said:
If you decide not to use it roll bars are actually still available new from Porsche (around £150 last time it came up).
Cheers Simon, that's seems good value form OPC, will check it out.
