High butterfly Efi conversion using aluminium cast Weber pattern itb’s
  • 911retrim changed the title to High butterfly Efi conversion using aluminium cast Weber pattern itb’s
Air filters will be ITG’s with rain hats,
The injectors are clamped in individually into a recast 911 R  manifold and supplied from a distribution block with built in regulator
Electronics are canems, and I have a map saved from a previous installation using this software, so this will be my starting point.
crank tigger wheel is 36-1 laser cut, mounted to a crank pulley, I’ve had turned from billet
throttle body bore is 42mm
Edited by 911retrim
This is a system that’s been in my head for several years, since I installed a set of Jenvys with Canems software. I’ve used a local foundry for the castings with patterns made by myself. Machining is done in-house, along with the design and folding of the ‘Mfi’ inspired linkage.
next stage is terminate the wiring loom, and go for a startup. I have a map for a 3.0 Carrera, so I’ll use that!
[URL=https://app.photobucket.com/u/hartwell5948/p/3f4425d6-f3da-4e73-a66c-e3340ac20442][IMG]https://hosting.photobucket.com/images/hh159/hartwell5948/154C0FD7-EAED-4B27-A087-3B1389A2C507.MOV?width=590&height=370&fit=bounds[/IMG][/URL]
[URL=https://app.photobucket.com/u/hartwell5948/p/1c862eff-87e4-4a9e-bc69-14c0d257a97a][IMG]https://hosting.photobucket.com/albums/hh159/hartwell5948/.highres/9EE5F4A6-2CEA-4930-9288-B969A543FEF5_zpsa5txv25g.jpeg?width=590&height=370&fit=bounds[/IMG][/URL]
