On 05/01/2022 at 22:28, Zohar said:
Can either poster please help with a link to the specific led bulbs ?
cheers !
I would be interested to see this too?
Not quite, they do a classic look LED which isnt a bright white colour, more a yellowish white
Ohh ok.
I couldn’t see any difference in the two links you posted.
Russ
Yes, sorry, I was on my phone and couldnt see very well, I did post 2 links for the same! But as David has pointed out, there is a white option
All plug and play, room for everything in the bowl
How do you get away with it on the 964 come MOT time. Swap them back back to Halogens for the day or just a Friendly MOT tester?
In a way I can see that that they don't want idiots blinding everybody with cheap Chinese knockoffs, but having a regulations that pre-1986 its fine to replace them, but post-1986 they are an instant failure, seems a bit of a farce. Surely it's more about beam pattern and aim.
https://www.gov.uk/government/publications/special-notice-01-21-headlamp-conversions/mot-special-notice-01-21-headlamp-conversions
Havent got a new MOT yet, if they fail its change back time!
I have similar LED bulbs and it passed its MOT recently, I think its down to how the tester!
The same garage has been MOT'ing my car for several years with the same bulbs so that may have helped
What did you don with the drivers ? Did you mount them to the body or leave to dangle inside bucket ?
cheers
2 hours ago, Dyaque said:
Photos please!
Only have this as didn’t take photos during install.  Took a few minutes to do, plenty of space for drivers. Will add to my non Porsche classics as well. Colour temp is excellent . Very impressed.
Which did you get in the end: the Classic Car LED H4 bulbs with the separate drivers?
If so, are the drivers just loose in the space between the light unit and the bowl?
Yes and yes , though i may go in and use some double sided tape to try and attach them - the bowl is , well bowl like so no flat surfaces.
Btw - also did the interior dome lights with the warm white led from the same company. Absolutely perfect.
