A long time ago (12 yrs or so) I fitted a headlamp relay kit and better bulbs to my car and noticed a real improvement.  Technology has probably moved on a bit now so I wondered what bulbs people had on their cars now?  These seem to promise quite a hike in strength https://www.eurocarparts.com/p/philips-12v-h4-racing-vision-150-150-brighter-upgrade-twin-pack-48177019R?gclid=EAIaIQobChMIz_mq9suL9QIVQuJ3Ch3vRA7ZEAQYAyABEgJX3vD_BwE
Recommendations for better bulbs appreciated.  Thank you
I have the Osram Night Breakers 150% plus in mine with a relay kit fitted. Look like a very similar spec to the Philips ones. I ran the std H4s with the relay kit for sometime before I freed the Osrams, they were a significant improvement over the standard H4s.
p
Thanks Phil, guess it’s worth me checking the spec of the improved ones I fitted all that time ago in case there aren’t any more improvements.
Not too white Ian, they don’t look out of place in my SC. I was worried that they might be blueish as they have a blue band around the bulb, but you don’t see this when they are installed/switched on.
p
  • 2 years later...
Bringing this up to date a little…. I saw a post on Pelican about Porsche offering H4 LEDs as part of their Classic line of parts.  It also reckoned that a Philips version looked very similar (….identical).  I was in OPC Nottingham today and asked about them.  It seems they are not available in UK as they “don’t meet UK requirements”.
I think it’s these, which you can buy elsewhere and are 300% more effective than originals.
https://www.ledperf.co.uk/philips-ultinon-pro6000-boost-approved-h4-led-bulbs-kit-11342u60bx2-p-125393.html?gad_source=1&gbraid=0AAAAADtkvO7hpfYNg4w31M36ME-c_v1dC&gclid=CjwKCAiAm-67BhBlEiwAEVftNhk1G65HwxQkbaf5BjZia6QGrZEAHo_e5HJNc5lIJEJcPE2rXkvPIxoCy0kQAvD_BwE
I have a set of Philips Ultinon in my van.
Just need to remove them
before the MoT though....
6 hours ago, Ian Comerford said:
Interesting, D911 seems to be selling the Porsche ones but no mention that I can see of not being legal for UK.  The Porsche price was £155 + VAT, so these are a little more pricey
https://www.design911.co.uk/porsche/911-1965-1989/lumetechnik-led-headlights/
Looking at the Porsche website. It looks like they are permitted in some countries, but no mention of UK.
https://www.porsche.com/international/accessoriesandservice/classic/producthighlights/led-approval-documents/
My Classic Car LED Warm White H4's with standard headlamps are far superior to halogen bulbs
I had them checked at my local MOT station, who said they had a perfect beam pattern and he would pass them without comment
 I believe they were £59 each, although even brighter warm white bulbs are now available.
Jason.
I’m using the Classic Car LED H4s, and passing MOTs
From their website
The MOT rules have been clarified from 06.02.23 to allow the use of LED conversions that pass the beam pattern tests for headlights for Class 3, 4, 5 and 7 vehicles (car, private bus and light commercial vehicle) first used before 1 April 1986 and all class 1 and 2 motorcycles of any age.
From their website
I have these in Jaffa 911 - good kit!
c
Some interesting comments here from a Pelican thread on the subject;
I have a lot of concerns about many of the offerings on the market, even more so when it comes to conversions. You talk to enough lighting engineers on the subject of headlights and you start to notice flaws in just about everything.
In an ideal world, there would be a plug and play solution for the factory H4 lenses. But none of those housings are designed for LEDs; they are designed to focus an incandescent bulb, and can’t properly focus an LED. That is, unless the design of the LED replacement disperses the light similarly to an incandescent (which that rather interesting one on page 1 seems to do, though it’s unclear). On top of that, the fluted lenses are designed to disperse incandescent light, and they don’t do it well with LED swaps, despite what people claim.
So many kits and replacements look really bright in front of the car, which fools people into thinking they’re great. But they don’t throw light very far, most not as far as the factory incandescents. It ultimately screws up your vision at long range.
Replacement housings can be properly engineered for more modern lighting, but they often have issues as well. Quality control is suspect, with sub-par/cheap LEDs, and some have bad throw patterns. They’ll have clean cut-offs, but won’t project light down near vehicle corners, so you can’t see curbs if you’re trying to turn (for instance).
Honestly, what we need is an independent company that’s an expert in lighting to test all the offerings for different cars and tell you what’s good and what’s not. A lot of “solutions” are fools gold.
 https://forums.pelicanparts.com/porsche-911-technical-forum/1169084-led-s-h4-housing.html
And just posted on that link above suggestions that standard lights with simple relays and all in good condition is as good as you can get.  Interesting!  It would be good to see a comparison test
  • 6 months later...
I just bought 2 new headlights from our resident supplier (thanks Matt) at Type911, lovely kit (now I need to sell the old ones).
They don't come with bulbs so I'm swapping the existing ones over, I bought osram nightbreakers a while ago and while they were good in my old headlamps I'm looking forward to seeing how they perform in my new ones.
If anyone wants me to test theirs nows the time 🤑
SS
Edited by SurlySurdi
  • 3 months later...
10 minutes ago, Ian Comerford said:
How did you get on with these Chris, are they noticeably better?
They are very good. You certainly won't fit them and think 'I wish I had more light'.
The only downside will be the need to remove them each year before the MoT.
But those with old jalopies may avoid this.
