So, i've been on it.....cam sprockets replaced, big thanks to HeadShop in Warrington and case closed up
20230819_113009.thumb.jpg.8281591d7998d6584fbe5e47f8d58d26.jpg 20230819_113017.thumb.jpg.e91f40dd56a4cfce4b9d37eeb6d6a717.jpg  20230819_221116.thumb.jpg.3e301990aa4d21acb0f21253e4dd90f9.jpg
With the help of a willing accomplice
Now on to the top end !
Nice job..to bad i could not tell you earlier not to use the blu o rings for the throught bolts...I hate those ,i only use green Viton there and for the whole engine ..
Engine looks clean..
P's and C's ready for install!
Cylinder heads and Cam Towers back tomorrow!
I'm flying this week!!
Before....
and after....
now studs........so many studs!!
Spray bar, studs and end-caps back in, waiting for spray bar access plugs to arrive.
And rockers stripped down and ready to go away for bushes and possible refacing.
Most of the shafts look ok but 4 or 5 show signs of wear and some small ridges.....guess they'll need replacing too!!
Febi replacements are 15 bucks, anyone got any experience vs original parts?
Some of the adjusters have also been abused in a former life, they'll have to be removed in the shop.
So I'm going to send them to the Head Shop in Warrington,  they did a great job with my cylinder head.
Nige ..i`m much closer to you if you like to have it rebuild;-).plus i`m very inexpensive....
I still have some room finishing 3 engines now.. what is the problem with yours?
Edited by proporsche
29 minutes ago, Nige said:
Can I bring my engine down for you to rebuild please? :)
Haha, thanks Nige, I'll take that as a  complement!!
Most of the time I'm fixing these things, it's just an evening hobby.....which maybe one day I'll get to drive!!!
Credit where credit's due....
I got these from an un-named, normally to be avoided porsche parts dealer.....🌹👩‍❤️‍👨
And they arrive in less than 24hrs!!
Tricky to get also........
Gezzer, I guess that's why your rebuild is super clean!
Ivan, I'll start saving up, though I have been for a few years but it keeps getting redirected into house related priorities.
Everyone needs a German vapour blasting genius in their life!!
Top turnaround (overnight) from Daniel now off to the UK!20231026_125301.thumb.jpg.72643d2c50f7334395cfae56454825d2.jpg
So my OCD is bouncing......
Dilivar studs arrived and the black over coating (whatever it is) has sent me into a wild panic.....!!
And the 8x20 studs that I ordered for the top of the cylinder head have come labelled as exhaust studs, and they're black instead of yellow zinc 😭
Think I'll go back to bed, it's safe there!
aha.....
P/N on Porsche manual
P/N from an unnamed supplier.......from  the the same diagram
I would be sending the head studs back.
 They need the corrosion protection and they are compromised.
To be fair they are exactly as pictured...on several websites so I'll send them for cerakote.......to feed my obsession!!
The aftermarket studs arent finished as well as the OEM versions
you're right, i'll hand them over to my friend to cerakote them, good heat and corrosion resistance......should have bought OEM!!
Very wise.
This thread is a beautiful thing, so much attention to detail and amazing cleanliness. What is it about clean and shiny engine parts that gets the pulse racing 😂
Thanks Phil, clean and shiny wins the race!!! 😂
So I'm going to start on the injection bits and pieces, getting ready for reassembly.
Here's a question,  does anyone know if this injection pipe holder is available?
It's bolted toothed side of the throttle body .
I want to remove it to have the bracket plated with everything else, needs to be removed by grinding back the fixings with a dremel.....then probably won't be in great nick to put back. Cant find anything in the catalogue....
Any top tips or www links well appreciated!
You can get the bracket plated with the plastic clip still in place.
Yey, Saturday night jigsaw....
and i managed to have matching number of screws and clamps after three years!! Boom shiny
20231111_205605.thumb.jpg.7e7f8a59796d070015da281069225e7a.jpg20231111_205632.thumb.jpg.4078aaf41df34c9bbcabb833146f16ad.jpg
Next...
Clean peened areas so as not to damage the new injector buckets, break out the dremel.....but go easy as the ali is super soft
