Has anyone found a suitable aftermarket seal to go round the oil cooler shroud. OE version is over £100!!! It looks like a simple U type edge seal but I can't find anything that looks similar.
Also how does the OE version actually fit? I've tried to open the U section up but it is impossible. Does the shroud plate just push into the U section?
Try some16mm water pipe insulation tubing.
You'll need to notch it on the tighter curves, but at under £1 it is worth the effort!
The existing OE section only has the U grip section not the hollow rubber bit on top. Did it fit OK?
Let me know how much you’ve got left please?
Have you tried Woollies?
There’s a “small boot seal” on there that looks similar.
Russ
Yeah, I'm looking at all the car trim seal suppliers and there are numerous types available which should suit the purpose.
I don't have access to the car as it's down at my Indy. How does the seal work? Does it face seal up against the inner surfaces or edge seal?
  • 3 years later...
Did you get anywhere with this?
The Porsche foam seal is a ridiculous £100 so I'm also looking at other solutions.
I did use one of the foam rubber U section seals but which one I can’t remember. Sorry.
On 13/07/2022 at 22:35, sopor said:
I have some stuff I bought from McMaster Carr in the US that was recommended on the Pelicanparts forum. https://www.mcmaster.com/12335A25/
need to check how much I have left, probably enough for another car
You wouldn't happen to have any left, would you....?
Seeing if I can find an equivalent in the UK.
I definitely used the U channel spring grip with a round hollow sponge rubber tube on top. Probably bought from Woolies or an ebay supplier. If I can remember it was the size of the sponge rubber tube which was the issue. But the bigger size didn't cause a problem in the end.
