Just acquired a 993!  It's a non-variorum C2 tip, non AC in metallic black.  Interior is black/marble grey.
It's done 95K and has service records back to 20k with the right people.  Sold by Paragon in 2007 and has only done about a 1000 miles a year since then.  Totally stock and not messed about with.  Drives absolutely lovely, no squeaks or rattles.
Of course, the engine was bone dry the day I looked at it but the next day, I was greeted to a big puddle of oil underneath.  After an initial panic, it turns out that there is a small oil filter that is prone to rusting and sure enough it had a pin hole in it.
Oil filter is above the heat exchanger orange rubber tube
What a rotter to remove, access is very poor.  Eventually after taking a oil shower, got it undone with the chain wrench.
It got pretty mashed up by the chain wrench but you can see the corrosion below
I've been reading about the Tiptronic which is not well understood.  There are 5 ECU maps and the car switches between them according to your driving style.
If you drive it like a Mercedes then yeah, it's a wafter.   On my brief first drive I managed to get it into the sport map on a twisty road by more aggressive throttle and braking inputs - it then delays changing up and sits in the upper RPM band.  There is definitely a technique to be learned.
Service kit should arrive today and then ready for the weekend!
Edited by Jonny Hart
Might be the wrong place to say it, but still the best looking "911" in the near 60 year development of the marque. 👍👍
Agree! Simply loveleh
I was lucky enough to have access to a 993 Cab Tip for a whole summer about 20 years ago. It was a real joy to drive, pleasantly quick when required to be and very comfortable on longer journeys, and yes a beautiful thing to behold - :steering:
Just a very minor observation and definitely not meaning to sound negative but for an oil filter casing to rust you have to question how well servicing has been done.  I guess you will be changing all of the fluids straight away, hence the service kit, so can start afresh.
It’s a great looking car by the way.  Will you be fitting ac?
What a lovely car, good work Jonny! I thought the same Ian, I guess the access issue and perhaps lack of knowledge.
Actually it’s a victim of the 12k miles service schedule.   This car has only done 1000 miles a year for the last 10 years.   So, the filter has been on the car 10 years but officially doesn’t need changing.     I also found out that when the 993 was launched, the intention was that the small filter was fitted for the life of the vehicle.    Porsche backtracked on this a few years later.
Anyhow, the oil that came out was honey coloured and no sign of any particles.   Yes, full service being done to start with.
Just for the sake of "geekery", the small filter was introduced on the 993 specifically to protect the hydraulic tappets.
Congrats on the acquisition Jonny.
:signs118:as always Mark :ani_nerd:
Looks Great Jonny!
Out of interest my 997 TT is a Tiptronic and if you give it a couple of "blips" on the accelerator while stationary it resets the mapping and the car is back to mental mode
Maybe the same on the 993 Tiptronic too?
DT
6 hours ago, World Citizen said:
Nice car Jonny, planning on EV'ing it ?
For me,   EV’ing is reserved for cars with lacklustre drivetrains.   So no, not this one.
7 hours ago, Ducktail said:
Looks Great Jonny!
DT
In Park?
1 hour ago, Jonny Hart said:
In Park?
I assumed this meant in neutral as when in park I think a different set of mapping criteria would be in play, would be good to know for future reference.
^ Well I just tried two quick 'blips' whilst driving normally in 'D' and the box changed down immediately!   Perfect for getting ready for an overtake.
Nice
That might be the "kickdown" mode
If you get the chance do the blips while the car is stationary then see if throttle response and gear changes are quicker afterwards...you could try while in Park and then again in Neutral..993 may be different to 997
DT
The 993 is throttle by cable so not much to be done in terms of adjusting throttle response.
I seem to recall the the 993-era tiptronic looked at how far you pushed the throttle open and how fast you pushed it open to select the transmission programme to use.
^ it also takes into account how fast you come off the throttle and lateral movement of the vehicle.  This prevents lazy upshifts happening on twisty roads.
Nice acquisition Jonny, have been thinking of getting something like that or a 996TT tip (would be cheaper here) for trips to the Big Smoke.
  • 5 months later...
Well, I just got back from Paris having been to the Retromobile show (which was excellent).  Got the car buttoned up Wednesday evening and left on Thursday morning.  I didn't even have a chance to take a photo of it clean so this is what it looks like now:
This is a car that has only done around 500 miles a year for the last 15 years.  So I thought I'd do 500 miles in one trip just as a reminder of how the car should be used.  It was faultless.  Must be getting old but the Tiptronic is a joy for a road trip like this.   I wanted this to be a cruiser - a different car to the SC.   A tiny car by today's standards which was handy in the Paris multi-lane free for all madness.
list of jobs done so far:
1. Brake and suspension refresh with 30mm drop and Konis.  Really nice ride.
2. Mk1 GT3 wheels and Michelin PS2.
3. Front seats stripped and recoloured (they had been done before, not very well and the wrong shade).  New door cards.
4. Dansk non-sport exhaust.  TBH, still a bit too loud at 2800 RPM.  Silent at 85 mph.
5. New lights/lenses all round.
6. Classic Retrofit 240A alternator
7. Classic Retrofit refurbished HVAC suitcase with our own servos and high efficiency AC evaporator.
8. Classic Retrofit HVAC Control Unit and replacement wiring harness.
Nice to get a mid winter road trip :)
Any issues with the Paris emission zone?
