2.7/3.0 'big' brake kit / conversion
Diesel76
I will take pictures later, however items are:
2 x used Boxster front calipers
2 x front CNC front caliper mounts
2 x front discs and pads (new in box)
2 x rear 3.2 Carrera rear calipers (require rebuild / paint)
This combo will work with stock master cylinder and provide the correct front / rear braking ratio. Requires 3.2 rear brake discs and pads to complete conversion.
£375 posted (UK)
Les, look into caliper/rim clearance, I have Boxster calipers on my 3.2 and there is only just enough clearance for a slice or two of wafer thin ham between caliper and rim.  I'm running 7s on the front.  Are you on 6s?  Also does the hub spacer need changing, I might be wrong on this one?  Nothing difficult to get over, but with yours being an SC this might not be 100% plug and play?  Though pretty minor things to overcome for a man of your skills and tiny hands.
Great value for all the kit nonetheless.
Edited by Nige
I thought about it 🤔 but have other things higher up the priority list (like a new fuel tank, tyres etc !)
Plus I already have 3.2 brakes all round on my SC :)
Edited by GaryH
