3.2 Carrera looking for advice on Price
rich73
Hi All,
The time to sell my 3.2 Carrera is approaching(1970 ST project is needing some expensive bits soon) and I was just trying to come up with a price to advertise it for. Agreed valuation by John last year was £56k. I was assuming that a sale value to aim for would be maybe 10% less than this.
I had a quick survey of ebay and pistonheads and most of the G50 cars were advertised at over £60K.
I know my car will have a smaller market as its modified but the counter is that I can’t see a similar track car on the market at the moment.
Car will be fully serviced, geometry done and  new set of tyres as the S02’s are getting on a bit. Second set of Fuch will be included. Current milage approx. 136K
Any thoughts welcome on what to advertise for, is 55K too much ?
20220523_163651.thumb.jpg.17300cfc1fb2bd3960ff6a1b2a621fe6.jpg20220523_162916.thumb.jpg.d83ed4b8cf7d31e6005183c9a49076b8.jpg
20220523_150055.thumb.jpg.20ed40a807ebfdde72819360aae75fc4.jpg20220525_161301.thumb.jpg.c0408f9a8f3ba76abb3d16c1a81d8e93.jpg
20220525_161431.thumb.jpg.d77ac650ce0ee99c7547394be2c849ee.jpg20220513_161940.thumb.jpg.c66f2c8e5b9a703f7c61f080af439885.jpg
Item
Modification / Work carries
Note
Body
Roll Cage
Custom Cages - 6-point TIG Welded
Seat Mounts
FIA MSA Approved Weld in Seat Rail Mounting 35mm CDS
Roof
Sunroof deleted
Bumpers
Fiberglass bumper blades
Lightweight Aluminium Mounting tubes
Engine Lid
Fiberglass Carrera 3.0
Rear Window
5mm Lexan
Rear Qtr. Windows
5mm Lexan
Front Screen
Laminated heated
Bonnet
RS Bonnet Prop
Interior
Seats
Sparco - EVO L
Harness
Schroth - PROFI II 6 point
Steering Wheel
Sparco - 380mm 3 Spoke
Fire Extinguisher
1.75L MSA handheld
Radio
Remove and Blank
Clock
Remove and Blank
Door Handles
964RS
Dashboard
Flocked Finish
Heating / Ventilation
Heat
Full backdate
Electrical
Battery Switch
FIA Battery Master 6 Pole
Fuse Panel
Classic Retrofit - Blade fuse panel, with headlamp relay
Headlamps
Uprated Power Halogen Bulbs
Power outlets
USB Power outlets x 2
Internal Lighting
All upgraded to LED
Engine
Top end Rebuild
At 132,500 miles by Nick Fuljames
Exhaust
Dasnk - Stainless 84mm 1 in 1 out
Transmission
Gearbox
Strip and inspect
LSD
Factory fitted option (code 220) Strip and Recondition
Clutch
Replaced
Suspension
Tie Rods
OEM Turbo
Front A arm Bushing
Rebel S Racing - (RSR) Front Bushing Set
Front Camber Plates
Tarrett  - Monoball Camber Plates
Front ARB Mount
Superpro
Strut Brace
Rennline - RSR Weld in
Front Damper
Boge/Sachs -Standard Insert
Rear arm bush
Rennline - Mono ball Rear Control Arm Bushing
Rear Spring Plate bushings
Rebel - S Racing (RSR) Rear Bushing Set
Rear ARB Mount
Superpro
Rear drop Links
Tarett - adjustable drop links
Rear Dampers
Boge/Sachs - Standard Insert
Wheels
Rear Studs
OEM 72mm
Rear Spacers
25mm
Nuts
 Steel
Brakes
Front Pads
Ferodo - DS2500
Rear Pads
Ferodo - DS2500
Front Brake Hose
Goodridge - Stainless Steel Brake Lines
Rear Brake Hose
Rich
I don't think its too much, properly sorted car with no sunroof, LSD and engine and box build. Hassle free car.
The only negatives for 'some buyers' would be the seats and cage. Definitely reduces market. But someone looking for a track 911 this would be perfect.
I think remove the sun strip and put some black seats in and the appeal improves for a lot of potential buyers.
That's really helpful thanks.
My partner was saying it needed black seats so new seats it is. Looked at second had but everything seems pretty grotty and expensive. I'm thinking of just buying a new set of Sparco evo L for £1200, I know seats are a personal thing and they may get swapped out by someone but they should give a nice feel  the car.
What do you think the issue with the sun strip is? Looks a bit too race car maybe. I was planning on taking this  off anyway but replacing with a new one as its damaged.
I'll remove it today and see how it looks.
Thanks again
Rich
the big money G50s are original cars , once you start ripping out interior bits and hoying in cobra seats ,  those buyers fall off a cliff.
not saying you necessarily dont have buyers, but there is a different buyer group and you need to find the guy who likes the mods.
pricewise, I cant help you much as Im not familiar with the UK market.
but 3.2 G50s are great cars. undervalued imho
Edited by axel
My advice would be to not remove the cage initially - leave it fitted as it is getting harder to add them to road cars.
The platform is perfect for a nice backdate for someone and lots of hard work is done. The chassis upgrades are all top notch.
I would not spend on Sparcos. You will not get that cash back. I am pretty sure I have seen EVO L seat covers for sale -  just fit new covers in black if you can.
I would try it as is on Car and Classic and see what happens. I have a 915 3.2 with similar miles in standard condition on there at the mo and it is quiet. A G50 stands a better chance for sure. Try it at £57,500 and see if any messages. If nothing after a week drop to £55k, then maybe down to £53,500 in week 3. The eventual selling price may stay roughly the same despite the different asking prices.
If it is staling then start looking at speccing back to stock, selling the bits on here and taking max out of it. August can be a very slow month so let the kids go back to school before you change much would be my advice.
Non-sunroof is a big deal for the right person so make sure that is in the ad title.
Thanks for the advice Everyone,
I’ve been using the car quite a bit recently, usually with a mountain bike attached to the roof and it does generate a lot of interest. I’ve had a couple of people who knew the value and seems genuinely interested when I said it would be for sale soon.
Listening to them, their thoughts were to use it as I’ve been using it, weekends away, taking out family, attending shows etc rather than as a track car.
It does have dynamat and a full set of carpets, the damping isn’t too harsh and I really did enjoy  driving  it 500 miles over a weekend a couple of months back.
What I was aiming for with the car  more recently was to make it seem more like a  factory RS/GT type car rather that something modified for the track. Its 964 RS door cards and Schroth harness were part of this. Its tempting to replace the wheel with one of these:
https://www.design911shop.com/p/porsche-classic-performance-steering-wheel--red-stitching-porsche-911---914---924---928---944---968---964---993---996---986-boxster/?currency=GBP&country=GB&gclid=Cj0KCQjw_5unBhCMARIsACZyzS0QnraASfwXdC8-f7I64brWihyognfg9D4dl1eH61rreeO2yeji9DIaAtpkEALw_wcB
 but as John said with the seats I presume its money I wouldn’t get back. Maybe a Porsche horn button for £60 maybe a step in that direction for less money.
·         I’ve removed the sun strip and it dos look better without it, thanks for that advice.
·         The seats seem to be something that everyone think needs sorting.  John, replacement covers was a great idea but looks like they were only ever available for the US market and are no longer available for  some reason. I’m definably going to be replacing the seats,  scanning ebay I’ve  come up with some options. Recaro CS looks like a nice  and there seems to be a few pairs about. Liking the 944 option too thanks Northy.
·         Really don’t fancy removing the cage, lot of work went into modifying the dash making carpets etc so would be a massive pain. One compromise could be to remove the door bars. Think I’ll leave them in for now though. They are mounted low but if they are an issue for someone I could easily remove them.
Thanks for the pricing advice John, I like that approach.
I’ve got some bits at the platers at the moment but hoping to get them back next week and hopefully all back together the week after that and get some pictures taken.
Thanks again
Richard
Thanks, we're really pleased with how they look. Given them a good clean today and hoping to get some time to fit them later this week. It was 180 mile round  trip to pick  them up, I'd forgotten how nice it was to drive on the motorway. 3k revs at 70mph, 3.5K at 85mph. Give it a full service including valve gaps and its running really well. Genuinely sad to be selling it soon.
