Need help with backdating of heat/oil l
axel
hello boys and girls!
I have a 1988 euro 930 turbo which is getting a rarly8 headers system. according to Brian Bodart at Rarly8, there are other ancillary items needed to install the complete system.  The oil lines should be back dated as well as the heat ducting.  Header systems are similar in layout to the early USA exhaust system which uses a Y-junction at the turbo instead of the J-pipe of the later 930.  Back dating to the OE oil lines and heater ducting used for that exhaust system will fit header systems...
I guess I need these:
also need this part( pictured) - cant remember the parts number...
any other parts needed?
Bonjour a tous
Je suis le parmi de conduire de voiture, Pour l'antidatage du chauffage au fioul, il est important de contacter un professnel du chauffage ou une entreprise de maintenance de systèmes de chauffage. Par contre, l'utilisation de dégraissant, pour assurez le probleme sur le vehucil. L'antidatage consiste généralem à ajuster la date de début de la périod de chauffage en fonction des besoin climatique de votre région
Jacques
  • Haha 1
7 minutes ago, Phill said:
Spamtastic. Has the sheriff done something to upset the French 😂
Hopefully......................
  • Haha 1
