I had to disconnect and remove the front callipers to fit new hub seals.  I did the usual with the reservoir to stop too much fluid exiting the system, a piece of plastic bag under the cap to close the cap vent and clamped the overflow pipe with hose clamps. It worked partially, there was still a small amount of fluid dripping out.  When I came to use my pressure bleeder after refitting the callipers it didn’t work at all, the fluid on the reservoir was bubbling due to an air leak.  It looks like the overflow piping has got old, been clamped too many times and is porous in some way.  I had to resort to manual bleeding.
T he overflow pipe is still fine in its primary function but now cannot be clamped to close it off.  Aside from fitting a new one is there another way of closing off the overflow exit?  Should I unplug the pipe and fit something else to close it off?  Any thoughts, other ways of achieving this?  Thank you
If you lot hadn't poo pood'd my suggestion of full flexi pipes many threads ago, Ian would have no issues removing the callipers without the need to re-bleed. Just sayin'
  • Haha 1
Fair point
Just remove the overflow, and replace it with a bit of better condition vacuum hose about 3 inches long and clamp that off.
Or, just trim a few mm of the end of the existing pipe. There is usually plenty of slack in it.
I have a short length of flexible silicone pipe with one end blocked (chain link pin and cable tie) complete with a quick release fuel clip. I keep it in the box with the pressure bleeder and just use it to replace the overflow pipe when bleeding 911's.
Thanks for the input guys, just what I needed.  Appreciated.  As suggested I’m going to make a block off pipe as a sure-fire way of achieving the aim but will also trim off some of the excess overflow pipe as well.
