Hi all
i just purchased a sealey vs820 pressure brake bleeding kit to bleed a new and empty system
on pressurising the system or trying too it blows fluid out of the reservoir overflow
should I block the overflow or am I missing something
it makes sense it would blow out through the overflow but nowhere does it mention any overflows in the manual
the resevoir is new as is the whole brake system
regards Keith
1976 2.7s by the way
You have to block the overflow.
Phil beat me to it!
Edited by Roy M
1 minute ago, Phil said:
Hi Keith,
Yes you need to block off the overflow.
Phil
Ps you should have a flexible pipe fitted to the reservoir overflow that is connected to a metal drain tube/pipe, that exits under the near side wheel arch close to the washer tank…
Yes, crimp the hose and go no more than 5 psi
Thanks for all your same replies
it’s fairly obvious that the pressure would not hold with an overflow open tube, I should have realised that ,
I’ll blank it off and keep the pressures low
i have 2 bleed valves on each caliper so will bleed from the outside first
Got 6 pot calipers front , 4 pot rears
cheers
keith
  • johndglynn changed the title to Brake bleeding the 2.7s with a pressure bleeder
