Door top sealing strips
Rustybum
Hi all,
I was wondering if I could tap in to the vast knowledge of you all?
I’ve just had a full, windows out resto/paint job done and, unfortunately, I didn’t strip it down.
It was done by someone who, for reasons I can’t go in to, is no longer available to ask how he did it.
My issue is, on the door tops where the window slides up and down, I’m not sure what seals I need and how they fit.
It’s a 1985 Targa and I’ve looked on the pet diagram and I’m pretty baffled as to how the items 6 and 7 attach.
I can see a rubbery felt like seal or something inside the top of the door slot (which has disintegrated) but I cannot work out how new ones would fit or which to buy.
Any help/photos would be massively appreciated!
Russ
6 and 7 are both inside the door.
no 7 as small studs which press inot holes in the door skin, this needs to be fitted before the glass goes in.
No 6 simply pushes onto the verticle part of the inner door frame.
No 10 is the seal on the outside of the sliding glass.
1 hour ago, Lesworth said:
7 is the felty one thats crumbled. Mine came off in bits too.
Brilliant!
Thank you for your help chaps👍🏻👍🏻
18 minutes ago, Type911 said:
Pipe cleaner!
Are you saying to buy pipe cleaner Matt?🤔
No, dont think they would work too well, they just look like pipe cleaners!
Oh no!!
I’ve just ordered a bundle!! 😳
6 minutes ago, Lesworth said:
Just take up pipe smoking and use them to clean it.
😂 being from Yorkshire, it’ll go with my flat cap and Whippet
