Hi all
Can anyone confirm oil quantity for 2.7s with engine oil cooler not external cooler
believe 8 ltrs ?
and oil pressures at 1000 rpm idle is 20 psi correct ?
newly rebuilt engine
regards Keith
Oil quantity
I have just looked through my original service book and it says changing engine oil 911s add 10 ltrs and add more if necessary
It does not state if this has a front  or just engine oil cooler
im assiming just engine cooler but the quantities seem high, mine just has engine oil cooler
any assistance appreciated
Keith
With front cooler it can be up to 11 litres, no front cooler  I would think 8 is about right, 1.0 bar per 1000rpm
Thanks mate
i have about 8 now
once the timing has been set up correctly I will run until warmed up then check and top up if required
do you know the BTDC timing settings for a 1976 2.7s my book doesn’t say
Regards keith
