Hi Guy's
https://youtu.be/fVPrmg-Akns
Driving me mad
Disconnected the clutch master cylinder linkage from the pedal to replace the nylon bush, the pedal jumped forward an inch or so, replaced the bush and the pedal would not go back down to allow me to attach the master cylinder linkage.
Stripped out the passenger side footwell, repositioned the ac evaporator to gain access and reset the linkage but now I get a clunk when pressing down the pedal and on the return.
It seems to happen as the linkage goes from a positive to a negative position, I have stripped it down a dozen times to grease but cant stop the clunk, if I disengage the spring it stops, clunks with and without the master cylinder attached
There is a slight play in the linkages 911 423 567 00 but no clunk before I disconnected the master cylinder linkage
Any idea’s I have viewed the writeup by Sladey but cant see a problem only done 60,000 so not much wear
kev
Sorry can't help, but that sound would drive me insane.
Mileage is not always an indicator of clutch wear, the previous owner may have rested his foot of the pedal (riding the clutch), and added additional wear, Age will also take its toll on spring plates etc, also maybe worth checking the clutch needle bearings and fork for wear but this will mean an gearbox drop.
