Good old Evostick, or any contact adhesive
I've struggled with the normal Evostick as it's so thick. Maybe heating it may have helped. Last time I did it I used contact adhesive in an aerosol. Plenty of masking up before spraying the shell. Then for applying to the seal I sprayed the glue into the can top and painted on with a paint brush.
For door and boot seals that fit into a channel do the glue wet on one side, usually its dry on both
Thanks, I'll give that a try. I normally wait till both sides dry and struggle to get them in.
