Merida went to the body shop two weeks ago for some minor rust repairs and things have escalated quickly - as they sometimes do - and we are having a lot more work done.
As part of this the sill covers came off ( the sills are fine , the torsion bar covers are not ) and I need to replace the hardware that attaches them to the body.  I can see in
IMG_7593.thumb.jpeg.b7b51add07dec1d859f75ad0e04735ef.jpeg the diagram that there is a rubber sleeve and bolt( 14 and 16 )  , but what do they attach to on the body side?
Cheers!
Those are welded on both sides but IIRC, the spacers/standoffs are only needed on the oil pipe side
Rivnuted mine too, used longer bolts and a nylon spacer to match the height of factory brackets.  Only thing you need to be aware of is that if you remove them in the future, due to their location/exposure, the bolts can seize into the rivnut and then the whole thing spins.  Maybe less of problem if you can install the square/hex bodied rivnut rather than the serrated ones like I did.
Anti-seize compound is your friend on this one
Heat from the oils line and heater channels didn't help, the copper slip just melt away.  Wasn't a big issue as I don't need the mounting points in the cars current format.
I used nylon nuts on the bumper bellows and infill panels.  Worked a treat
Nylon bolts are OK, but usually heads usually snap off when unfastening if they're slightly stiff.
Can one of you gents please post  a coupe of photos of what it looks like with the rivnuts?
Cheers !
Here you go. First picture is what they should be like with the brackets. Two of mine had rotted on the offside so I rivnutted them about 10 years ago. While its worked fine, while my car is being painted I am having these two replaced back to standard.
Thanks.  I’d like to see a pic with the covers on, the spacers and bolts of you happen to have one.
1 hour ago, Lesworth said:
Sorry, I dont have one of those.
No worries thanks
Sorry not spacer photos, but the second time I did the mounts for the oil lines I used these weld in captive nuts.  If it's pre paint then I reckon these are much better than rivnuts.
tumbnail_a4bbd0fa-87c8-48e6-8e46-3dc3a87
Cool
my brackets are gone and the car is painted so I’ll make a hybrid of those with the stainless rivnuts and longer spacers
