Fuse Box Required
Guys
Is there any difference between the 3.2 and 930 fuse box or are they the same basic part? I will need to replace mine (930) in the near future as well as the fuel pump? I am about to commence the search and costs involved so any feedback would be appreciated :)
Guys
Hi,
Is your fusebox like this http://books.google.co.uk/images/cleardot.gif ?...i'd advise changing to a later fusebox that uses ATO fuses (plastic blade type )...we use one from a company called Vehicle Wiring Products.
Can you post a pic and i'd pleased to help with any info.
Derrick
Guys
Des,
Probably telling you something that you already know but there are two pumps on a 930, one front & one back. My past searches on Pelican suggested that they're best replaced in pairs as they run in series; the logic is that they wear at a similar rate and renewing only one quickly takes the other out. I'm not sure this would pursuade me to do both at once but it might be worth phoning a few specialists who know 930's to get the benefit of actual experience. If it's low fuel pressure rather than a very noisy pump then the problem could be with either.
Des,
Thanks David sounds expencive, anyone know the aprox cost of F&R pumps bet its £5/600 just for parts?
Des
