Sladey's 3.2 Backdate Hot Rod
  • Replies 171
Thanks twinny,
It's actually moved on a bit since the last photos - started to weld some stuff back in - which feels good after a lot of cutting out
looking from inside at rear passenger side floor
Now replaced
Another flange repaired (wiring has now been resoldered as well
And another
Heroic!
+1! Good skills Sladey - I can see you have been practising with the welder.
Hi Nige! Hope all is well with you. Nothing much to report on the car - still got it and carried on doing bits and pieces albeit nothing for quite a while. Even though I've been distracted by other motors and projects, I check in to the old Porsche forums every once in a while and it rekindles the love.
Thanks Chris
It's moving forward slower than I'd hoped for - mainly because of the extensive amount of fannying around at the front and back of the floor piece (weld/grind/weld/grind/weldd/grind etc)
Anyhow got some epoxy mastic on this week-end
You'd think so wouldn't you Andy! Apparently you have to do more than spray the outside to stop the rust from spreading. Little or nothing was done at the time and I assumed they'd applied some sort of protection but they hadn't. They are more used to dealing with modern cars with a full e-coated shell. Whilst it's annoying, I've had 6 years to get used to the idea and am looking forward to the feeling that it's been done properly.
Steve, I'm using a portamig 185. I've got nothing but praise for it. I turn it on and it works consistently every single time. I previously had a SIP migmate thing - I had to a fair bit of work to improve the wire feed etc. So a couple of years ago the portamig was a birthday present. They aren't cheap but worth every penny.
  • 5 months later...
OK Ive been updating regularly over on DDK but thought I'd pop a summary onto IB
Basically the car is still off the road but should hopefully be back on the road next week.
Since the last report
Cut down my torsion bar holders
a23777653d6348e0b6a141e3eaf76214_zps9cbd
Because I fitted these puppies
C29B0753-98D1-432C-A2B2-7B925FA2C7EF_zps
Front inner wing done
572DF0D5-EFC4-4BF0-845B-CC7D3B8DB7E3_zps
No torsion bars means no need for holes
efd50c6f149ab011ffd0ac73f2287789_zps5a24
Then decided I could improve the wheel arch shape
from this:-
E0B3F172-C84F-48E1-B6DD-47BA6407ECBB_zps
to this
060cb557e5c5b43dc60ab6929ed40940_zps4307
Same at the rear
e6f83e39be4a7a461c384a419027f0db_zpsec49
tried to do a second update but it doesn't seem to like it
panels back on
6bf335bea776fc8ce5aeac2945bfa3bf_zps4190
Carbon bonnet
6D8BFC7F-4D2E-47F8-91E3-0A4BDF8C6039_zps
Strengthened rear shock mounts - mmm gussets
C89D336F-A072-40F1-B9F9-B0419DEEE2D9_zps
Black engine bay
6B3F50F4-F34A-45FB-A1F8-E0ED16E06A69_zps
After friendly suggestion by T Boy, went to work on the sunroof
34F5FB08-48CE-476B-AB8E-C9E72D359D1B_zps
Full engine rebuild by Mike Bainbridge
CCE69839-0979-40C0-BB64-DE858670A9B8_zps
The Cavalry arrived (in the shape of Neil) to help with/Do the other side
95A72A94-741E-4E3B-8B55-2D19872CD08B_zps
Snapped exhaust stud
6F2C1476-0E9C-4B1A-8594-49842BEACEC8_zps
Drilled out
72369A04-9E62-480F-92DC-4FA9ED57BF26_zps
Ready to go back in
49189EB9-5C3B-4A34-BDE4-CE7815689934_zps
First startup
More metalwork
15489537-2210-49CA-9084-2B0FF2E56347_zps
Nearly there - Neil doing all filling shaping and painting - and doing a cracking job
0C9C00A4-8AE0-4688-A208-91E050A0D598_zps
Current position -
9FDFBFAF-9E27-4A2C-A738-E76B599096EC_zps
Spraybooth now finished. Final primer going on today
Colour going on tomorrow and Wednesday.
Excited. Very, very excited.
Wow top work Sladey! Very impressive work.
Who did you get the carbon bonnet from? One of those has been on my radar for a while, though silver told me they aren't much lighter (1kg?) than an fg one but twice the price! Is it because they are a better fit than fg?
Far more interesting thread than the values one ;)
Ha! yes I'm not much interested in values
I got the carbon bonnet from Nick at Early 911. It's a really good fit. If I'd wanted to run exposed carbon fibre it would have been good enough for that - quality item
From Nick:- "The standard steel bonnet is around 10 Kg, aluminium is 4.8 Kg and carbon is around 2.5 Kg"
Its VERY light
2.5kg!? That's a tasty weight saving! I thought the steel bonnets were 19kg? The CF bonnets from EB Motorsport were 5.5kg whilst their FG one was 6.5kg (from memory) hence me asking!
That and your sunroof delete should be an excellent reduction and very noticeable. :cool:
Edited by MarkJ
Thanks Ben
That's what I'm hoping - helped by the newly built engine
I went with 250 lb/ft in the end (I think it's lb/ft - it's been a while since I put them in). Elephant were recommending 300 lb/ft for their 'canyon carver' but they generally like things a bit stiff over there. I've plumped for the 250 as I'm trying to recreate the feel I had before. Going hard or softer is no big deal - probably £60-£70 in new springs and an hour (tops) to fit them.
Setting rear ride height is now a 5 minute job :cool:
I went for an RSR setup - I cant remember what rates they use. I have the invoice somewhere. But I agree, ride is such a breeze now.
I'd be interested to know when you get a chance
One man's firm is another man's soft. Can't believe I've just written that.
My previous stock torsion bar setup was just right for me - so I'm going to try and recreate that. Be interesting to know the RSR setup though
