Hey budgeteers,
Here's my recent budget refurb of the the flapper boxes. Mine weren't too bad. A bit of surface rust, but the mechanism was stiff and the butterfly seal melted.
I started by taking everything apart, and sent the housings and wheel of for blast and powder coat (£30) then started with the butterflies themselves.
Drill out the six rivets in the butterfly and separate the two halves - the black stuff is the hardened melted seal:
I got some 2mm silicone rubber sheet for a fiver off ebay, make template:
Cut oversize and remove centre strip for control rod, add holes (use leather punch)
Re rivet
Offer up to flapper and trim curve
I recently acquired a 1930's Myford lathe (£50) so remade the cracked and brittle swivels out of PTFE bar:
Once these were made I reassembled the unit, with new swivels and spring:
On the end of the flapper cables there is an aluminium end that had completely crumbled away. Made these replacements from 10mm ally bar:
Old versus new:
On the car:
Final result:
As you can see there was a small hole after blasting but that isn't really going to effect the heat output so I can live with that. Levers in the car now silky smooth.
best fresh flap joke wins a lifetime supply of toffee crisps...
:signs118:
Don't. I spent the morning speaking to a wheel manufacturer about how to test for "abnormal flange distortion".
  • 1 year later...
I know just the girl that fits this description.............Lol
Radial or lateral run out?
Either depending on position............................................... :ninja:
