Rebuild time (part 2)
You can certainly see why you need to twin plug with that shape of crown.
Er- just to check my engine knowledge RB :huh: , do you need to twin plug because that shape of piston crown divides the combustion chamber into two halves, reducing the flame front and potentially causing detonation, the two plugs ensuring that both halves of the mixture are properly ignited ?
  • Replies 85
Exactly grasshopper !
Looks that way doesn't it. Does your engine builder deburr (or whatever the term is) the sharp edges?
here are a few comparison photos of the different style of pistons
A Max Moritz 3.2 single plug compatible piston, crown is high and flat although sloped towards the spark plug apparently
A 9.5:1 JE showing a flat top crown but sloped again towards the single plug, Whose piston is this I wonder :whistling:
And here is an RSR style piston which has a really high domed crown that splits the combustion chamber in two and needs twin plugs
And my JE's with flat crown but no slope, better off with twin plug for sure, but its not as peaked as an RSR style piston so single plug might be an option?
I'm going to ask about the de burring
Haha - I 'knew' you were going to say that :rlol:
I was assuming that since you're keeping the CIS (for now) you'd be going Max Moritz pistons Bruce ? Btw, what are you doing distributor-wise for your twin plug setup ?
Edited by GaryH
After mucho pondering of all the options, I decided to keep the engine in 3.o form with the rebuild spec like this:-
Tuthill spec lightweight JE pistons
Clewett crankfire twin plug
The crankfire ignition has arrived in Greece but is now stuck in customs at Athens airport.
I was hoping for VAT and duty free ride through customs and had a good plan to achieve it, worse case was VAT at 20%
It looks like it has back fired badly. Greek customs want the following payments on a commercial invoice for $1900
VAT and taxes......................225
cutomes clearance ................100
Paper work fee......................40
handling charge.....................50
management fee....................50
other ....................................15
grand total to you
Mr Englishman in a hurry .......480 euro's or 330 quid :o
thats 35% of the purchase price, the robbing feckers
I was thinking the same John - there must be a way to dodge it somehow with a cheeky forward of some description.
If not what a bummer - no doubt assigned to the "lets forget about it" part of your brain so the pain should be short lived :)
Took the pain and paid up so now I have this:
Here is the complete twin plug kit
these are the coils, six in total and very heavy
Here is the box of tricks that makes it all work
this bit fits in the hole where the distributer went
I chose Clewetts own ignition wires in "non bling black" for that sleeper look
and finally some small brackets to stop the bottom spark plug caps from falling off
the engine assembly is coming on fine and is on schedule for the end of the month, fingers crossed.
Unexpectedly though there appears to be a bit of wear in the valve guides, more than would be considered usual after 5000 miles, so another new set of guides are going in as we dont want valve heads getting all hot and falling off!
before the end of November ACE, I have just repacked it and it will be on its way to Essex tomorrow,
You should have just sent it to Ace's house, he has a regular trailer service to Neil's place :D
Kidding Ace - any more news to put in your other thread?
Well the end of November came and went, ACE did his queue jumping bit (surprised Carlo did not step in as well :P ) but finally the engine build is almost complete. It should be running late tomorrow with a bit of luck.
I hope to collect the car monday morning, fingers crossed there are no problems over the weekend
Finally the car is back in its garage in Guildford and running :ani_clapping:
I had planned to collect the car on monday but a phone call late on sunday night delayed this a bit.
My engine oil coiler had sprung a really bad leak. There was no option other than to replace it, so a new euorcarparts item ws fitted on monday. I tell ya you dont want one ot these things failing, talk about an arm and a leg!
So pick up was arranged for tuesday, a nice clear day for a run up to Essex. The engine runs a treat, its very very smoothe and quiet, no problems at all with noisy JE pistons lurveerly. The exhaust makes a nice bark as well, and to my rusty IB ear did sound sharper than the old engine, I think this must be the twin plugging.
The instalation of the pair of crankfire coils prooved a bit difficult with the bulky CIS injecgion system. One coil pack fits a treat on the engine bearer in the same position as the 993, but finding space for the other prooved tricky and it sort of sits where the old coil went. I'll move it later for sure but for now its works. The ignition brain is currently temporaraly installed inside the car on the rear quater. It is soon to be moved out of site under the rear speakers.
The motor is going to get very carefuly run in, so far I have racked up 300 miles on a retared ignition setting but it feels eager enough. There is a slight problem with the clutch which wil be sorted later, other than that it needs more miles on it before setting up with power runs on the dyno.
So I've left it in Guildford with plenty of petrol in it and told the old man to get cracking!
The engine has nearly a thousand miles on it now without incident.
Should be over the 1500 mile mark soon with a nice weekend run up to the NEC autosport show on Saturday.
The car is then off to the Harvey's for final setting up on the rolling road.
So should all be ready by mid February ready for Snetterton.
The engine now has 1500 miles on it, and its sounding good so yesterday I took it out for a bit of butt dyno testing in advance of a trip to the Harvey dyno this morning.
The crankfire ignition timing had been set very safe for running in, to make sure there was no chance of detonation. So with a few tweaks of a screw diver on the ignition box I dialled in a bit more advance. The engine certainly picked up better but started to detonate around 4500rpm. A bit more tweaking and it the engine was running ok but was still way down on power.
At this point I was a bit dissapointed as it seemed the engine would not take enough advance to make good power without detonating. :(
Anyway an early start this morning and the car was on the dyno by 10.00. Very quickly it was apparent that the fuel mixture was very very weak, anywhere between 0% and 2% CO, it needs to be around 5%. So we called off any further runs today and the car is with Neil pending a modified WUR to get the mixture right. The car will go back on the dynop later his week. So with the mixture set right confidence is high that the engine will produce good power.
The morning was rounded off in the local greasy spoon called broxborne Delight cafe with ACE, Carlo and Charlie(mini Carlo). :)
There is no doubt that the engine is very quiet, just fan noise and raspy exhaust as Casrlo said. There is zero mechanical noise from the JE pistons which seem to be working a treat.
Any how a little bird tells me Dangers new engine, which is a very similar spec as mine, will be on the dyno tomorrow, should be useful to compare notes
Edited by bruceb
